pt pulls to the left
Old 29 Dec 2009, 06:49 pm
Default pt pulls to the left
have 2001 that I have replaced both control arms ,both outer tie rods, stabilzer links and the rear bell crank. I had the front end aligined. Car still pulls to the left when i let up on the gas or when trans shifts. any ideas?
Old 29 Dec 2009, 08:08 pm
fastdel's Avatar
Send a message via MSN to fastdel
Default Re: pt pulls to the left
looks like you have a alinement issue
best thing is to get it looked @
it could be someting simple like arm needs taking back off and refitting
as it only take it to be a out a very small amount on the mounts but by the time it gets to the otter edge of the tyre the incorrect alinement is even more out
other thing to check is to make sure brake caliper is not sticking and always contacting the disc / rotor as this possibley could make car pull to one side
ALSO KNOWN AS JCCC
Old 31 Dec 2009, 12:00 pm
Samson's Avatar
If your tires were not replaced at the same time you had the front end work done, then its the tires. PT's are very touchy to the condition of the tires. If the car pulled for any amount of time before you had the work done, the wear pattern will continue the pulling.
Door Lock Pulls JolieCruiser General PT Cruiser Discussions 5 24 May 2008 10:08 pm
Changing Door Lock Pulls JolieCruiser General PT Cruiser Discussions 4 13 May 2008 01:32 am
Just left a deposit for a PT Ctown General PT Cruiser Discussions 20 27 May 2004 04:45 pm
Removing Door Lock Pulls CHROMEDCRUISER Interior Accessories Forum 4 05 Jan 2004 04:32 pm
PT Cruiser zipper pulls Mary39 General PT Cruiser Discussions 1 07 Jan 2003 09:51 pm
