Broken Engin Mount
Old 31 Dec 2009, 06:42 am
Default Broken Engin Mount
Had my timing belt replaced about a month ago and now my upper motor mount is broken. Did they do something wrong when they put it back on after the repair? Or do the upper mounts break every now and again.
Old 02 Jan 2010, 12:14 pm
Default Re: Broken Engin Mount
Anyone? I think it is strange it broke after the belt was replaced. Is there a "right way" to install them?
Old 02 Jan 2010, 01:56 pm
The stock mounts are very flimsy at best and break often. The motor mounts for the neon srt-4 are stronger and will fit.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 02 Jan 2010, 02:29 pm
Thanks
Old 12 Mar 2011, 12:56 pm
If I go to a place like Pepboys and ask for the srt mount will I get a better mount or will I have to go to Chrysler to get a good one? I just had a PT lower mount break again.
Old 12 Mar 2011, 01:18 pm
UptownSport's Avatar
Fill (partially) with 3M windshield urethane.
Forever fix.
Old 12 Mar 2011, 01:27 pm
mityqwik's Avatar
Thumbs up Re: Broken Engin Mount
last year i replaced my lower mount three times,and i never gave it any thought to look at my upper mount. the 3rd time around, i looked at the upper mount and it was trashed,i replaced both upper and lower and have not had them break yet. its going on 10 months now and i keep my fingers crossed it wont break:wh istle:
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 12 Mar 2011, 01:42 pm
Yes, the SRT4 mounts are stronger. I've got both on the shelf in the garage I'll post pics of the differance later today. The upper strut is adjustable and there is a "setting" measurement that the upper strut should be set to. I tried to scan the page with instructions, but it isn't very clear. Maybe you can read through the "fuzzy". If not I'll try again later today.
On the PT with the automatic tranny, If you make the mounts to stiff, you'll end up with numb fingers from the vibration that is transmitted mostly at idle. Stoplights will become a nightmare. The SRT mounts will last longer AND not produce the vibration, if installed to the correct measurements.
Jerry
Old 12 Mar 2011, 03:53 pm
Here are the pics of the stock torque strut versus the SRT4 strut. Notice that the SRT's ribs are filled almost to the edge of the cups. The stock struts are noticeably farther down in the cups. You'll also see in the one side pic the slot at the "small" end that allows you to adjust the strut to the 4.72" measurement.
Jerry
Old 12 Mar 2011, 03:55 pm
A couple more pics of the SRT struts.
Jerry
Broken bolt KingKole02 Wheels, Tires, Suspension 10 13 Apr 2010 12:50 am
oil cap broken? evviee General PT Cruiser Discussions 1 16 Sep 2009 03:02 pm
Broken front motor mount ksquared11 General Turbo Discussions 18 26 May 2009 09:32 pm
PT broken when paid for Ervin48 Tech & Performance Forum 5 12 Sep 2007 07:56 pm
The engin =( coboltslab General PT Cruiser Discussions 4 13 Jan 2005 05:25 am
