Power Steering problems
Old 03 Jan 2010, 03:17 pm
Default Power Steering problems
Everytime something happens on this car, is an issue Ive never come across, and its always new and hard to figure out.
Im getting air into the power steering system. I know there is the one large hose that runs from the front of the reservoir, down to the pump. and the smaller one in the back runs down to the rack and pinion. Would those be the leakers?
I dont know why, but the big hose is always moist, like its porous, and the fluid is leaking out of the hose itself.
Also, is there a way to drain the entire system? and just start fresh with new fluid. I want to put good power steering fluid in it, cause it looks like this stuff gets really jelly in the cold.
Old 03 Jan 2010, 06:29 pm
Default Re: Power Steering problems
If you are getting air into the system, it is probably coming from an air leak on the reservior or the hose to the pump.
From the pump to the gear there is a pressure line that if it was leaking would not allow air in unless you let the fluid get really low.
There is a return line that brings fluid back to the pump that would be the second place to look.
I asssume you have bled the air out by lifting the front wheels off the ground and rotating the wheel all the way left and right three times.
If you are not losing fluid (the leak is what would fix your problem), just continually getting air back in, I'd check the reservior and it's hose first.
Old 03 Jan 2010, 10:18 pm
I dont think I am losing fluid, and I will have to check, but I think, and I cant imagine why, but she said the dealer replaced some power steering lines before she bought the car, and If I remember correctly, the feed line down to the rack and pinion IS OFF THE SHELF BULK HOSE!
Ive bled the system before, but it didnt stop the problem at all.
Old 03 Jan 2010, 11:06 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
if your pt is a turbo i have both pressure and return hoses NIB for sale. 140.00 shipped for both. i bought them when i lost my power steering. turns out all i did was blow the line off the cooler.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Ignition and Steering Lock Problems PTNoob01695 General PT Cruiser Discussions 10 12 Aug 2012 02:57 am
power steering problems bluebeard Tech & Performance Forum 1 06 May 2009 07:07 am
Anyone that has steering problems... Please post nbr10 General Turbo Discussions 38 02 Feb 2009 10:24 am
Help...No power steering scottw General PT Cruiser Discussions 17 21 May 2008 09:13 pm
steering problems: 2005 convertible bobsackaminnow PT Cruiser Convertible Forum 0 13 Sep 2006 06:56 pm
