code 352
Old 09 Jan 2010, 01:53 pm
Send a message via MSN to coco1476
Default code 352
2003 pt cruiser na automatic 89000 km engine code is giving me code 352 how can i fix it. thanks for your help
2004 pt none turbo
Old 09 Jan 2010, 02:03 pm
Default Re: code 352
P0352 (M) Ignition Coil Primary # 2 Circuit - Peak primary circuit current not achieved with maximum dwell time.
The Powertrain diagnostic manual indicates the following possible causes for a P0352 DTC:
Good Trip Equal To Zero
Ignition Coil
(A142) ASD Relay Output Circuit
Ignition Coil Driver Circuit Open
Coil Control Circuit Shorted To Ground
PCM
PT Do-It_yourself.com recommends a scanning tool that can better pinpoint the reason for the fault code.
Old 09 Jan 2010, 03:18 pm
Thanks crewzin, I guess i don't have a choice but to bring it to the shop. Unless someone had the same problem before...on idle it runs ok and when i give it gas it starts to stumble and sometimes dies, after it dies I just put the ignition key to off and then I start it up again it starts fine but as soon as I give it gas it starts acting up again
2004 pt none turbo
Old 09 Jan 2010, 03:25 pm
Here's something to read:
had code saying bad coil on 03 pt cruiser turbo ... - JustAnswer
Old 18 Jan 2010, 01:50 pm
Hey Crewzin, I tried everything that was on that link but nothing changed. Do you think the PCM could be shot or something loose inside? If yes can I just buy on at a scrap yard and install it myself without reprogramming it?
2004 pt none turbo
Old 18 Jan 2010, 05:19 pm
I'd sure find someone with a scanning tool before going out and buying a new computer. I do think it has to be the right computer for your car and it probably does need to be re-programmed.
Code Help jennylyn General PT Cruiser Discussions 1 21 Sep 2009 01:57 pm
344 code jkinard73 Southeast PT Forum 2 08 Apr 2009 12:54 pm
what is this code medtwo Tech & Performance Forum 2 04 Dec 2008 07:54 am
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
HU code ? 03LtAldPTGT Sound and Security Forum 3 01 Jun 2004 05:07 pm
