2008 PT Starting Issues
Old 14 Jan 2010, 04:53 pm
Cool 2008 PT Starting Issues
I have a 2008 PT Cruiser with 50k. I noticed that it was hard to start (like a low charged battery) when I attempted to start the car. The next day it seemed to start just fine. The next day it started just fine and I drove it to work. When I went to start it after work it would not start. It only "clicked" a couple of times, then nothing. It did jump start with no issues and I drove it home (at night with lights on). I put it on a charger overnight. It started fine in the morning, but then again it would not start after work. Is this a battery problem or alternator issue? When I checked the battery (with engine running) using a volt meter (at the battery post), it was measuring at 18.4 volts. Is it over-charging? Isn't that just as bad as under-charging? Or is there a different or better way to check it? I think that it should read around 14 - 14.5 at the battery while the engine is running, is that correct? Thanks in advance for any help and advise. Steve.
Old 14 Jan 2010, 07:31 pm
Default Re: 2008 PT Starting Issues
Welcome.
Sears & some other places test charging system and battery for free.
How do the terminals look? All crudded up?
Old 14 Jan 2010, 08:25 pm
Thanks for the "Welcome"...
All of the cable ends are clean and look good. No corrosion has been seen on the battery or cables.
2002 Pt cruiser starting issues ort102 Tech & Performance Forum 5 11 Jul 2011 07:28 pm
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
Newbie here; same PT issues Wienerdog General PT Cruiser Discussions 11 04 May 2009 11:57 pm
2 Issues - Need Help 07PTSilver General PT Cruiser Discussions 2 09 Dec 2008 03:45 pm
security issues dollymama Interior Accessories Forum 3 20 Apr 2004 04:18 pm
