DASH HAS DIED ! HELP
Old 17 Jan 2010, 02:41 pm
Default DASH HAS DIED ! HELP
Hi Guys,
I had to jump start my Diesel PT Cruiser as the weather over here in the UK has been ugly to say the least.
Initially my dash lights etc worked but when I started it an hour ago everything on the dash was out, the engine lights, all the gauges and the mileometer etc even though the engine turned over and started. I ran it for about 20mins turning the engine on and off but the gauges, mileage counter and engine lights did not come on, and are still off. The interior lights coming off of the rear view mirror work but not the central light that comes on when the doors are opened. I have checked all the fuses in the internal fuse box, can anyone give me an idea what has happened please, and how i can resolve it
Regards
Chris
Old 17 Jan 2010, 03:54 pm
Default Re: DASH HAS DIED ! HELP
Chris,
Welcome to the forum. First of all, as you know (or maybe don't), the diesel isn't made in the U.S.A. so the whole wiring system could be different. On this side of the pond, with the 2001-2005 models, there's a fuse box in the engine compartment that could contain your problem. An IOD (Ignition Off Draw) fuse is the #17 fuse in that box controls all sorts of things. If you have that PSD (Power Distribution Center) check all the fuses in there.
Old 17 Jan 2010, 05:00 pm
yes there is a fuse box in the engine compartment, thank you i'll check the fuse you have mentioned, i'll tell you how it went, its 10pm here now so 'ill do it first thing in the morning, regards chris
Old 19 Jan 2010, 04:36 am
Cheers CREWZIN !!!!!!!!!!!!!!!!!!!!!!!!!!! It was the very fuse you mentiond, It was a covered fuse , or should I say a fuse that had a black holding surround over it, however the fuse had not blown it was loose, when I shut the bonnet down hard it seemed to dislodge the fuse , so I pushed the terminals closer together, hopefully it has rectified the problem all is good now, Thanks again
Car just died loudassz Tech & Performance Forum 5 28 Apr 2011 06:24 pm
02 pt died and won't crank over ronwins3 Tech & Performance Forum 16 23 Dec 2009 06:25 am
My car died while on the road!!! damilleniumboy Tech & Performance Forum 13 30 Mar 2009 12:03 am
2002 PT died on me...HELP miklin Tech & Performance Forum 4 05 Feb 2009 09:19 pm
turbo died serape General Turbo Discussions 18 05 Jun 2003 01:47 pm
