2004 leaking oil on passenger side
Old 18 Jan 2010, 05:58 pm
Default 2004 leaking oil on passenger side
I Have an 2004 Pt that recently had the oil sending unit replaced.... It is now leaking oil on the passenger side down into the plastic shroud. It has to be leaking from somewhere near the top of the engine because it looks like or sounds like rather it is leaking onto one of the belts. The car has 112,000 miles on it and this only problem we have ever had with it other than the sending unit. There is no oil on the oil pan, and no oil coming from the new sending unit. Anyone ever had this problem?? I was thinking it might be coming from the valve cover??? Any help would be greatly appreciated. Other than that the car than that the car is running great.....
Old 21 Feb 2010, 05:57 pm
Default Re: 2004 leaking oil on passenger side
Yes. Its most likely the front crank seal. The crankshaft, or thrust bearings were bad from factory, causing too much end play blowing out the seal. I have the same problem with my p.o.s. '06 with 36,200 mi. on it right now. Just replaced seal yesterday, started it up this morning, and its puking oil out again.
Old 22 Feb 2010, 12:12 am
Mine ended up being the sending unit, I replaced it and it is no longer a problem.
Old 22 Feb 2010, 07:47 am
This is running out right behind the crankshaft pulley when engine is running.
Water leaking onto floorboard drivers side JolieCruiser General PT Cruiser Discussions 22 25 Jul 2015 07:48 pm
Convertible passenger side windows don't go down gipper65 General PT Cruiser Discussions 4 14 May 2007 12:39 pm
Passenger side airbag pt-banjeral Tech & Performance Forum 6 13 Jan 2006 09:36 am
wtb passenger side armrest josheypt Interior Accessories Forum 0 06 Nov 2005 03:30 pm
Passenger side grinding KingKole02 Tech & Performance Forum 6 13 Jan 2005 04:10 pm
