2004 Turbo boost?
Old 19 Jan 2010, 03:43 am
Default 2004 Turbo boost?
Greetings from a Newbie. I just got a 2004 Platinum model, and I note the turbo only produces 180HP, whereas other models are in the 210-220 range. Is it the same turbo with just a lower wastegate setting. Can it be boosted without damaging the motor?
Old 19 Jan 2010, 06:15 am
Default Re: 2004 Turbo boost?
Welcome.
Yes, you have the "turbo lite" - like I do.
Yes, you can up the boost - but then you can't run regular gas in it, you'll need premium.
What you want is Stage 1 - It's an engine CPU replacement - sometimes you can pick one up from someone who traded in and put original computer back - the S1 has to be for your model year and it will have to be programmed with you vehicle's VIN (a place called Flight Systems can do it, or dealer).
Old 19 Jan 2010, 09:25 am
ROCKETMAN8060's Avatar
Cool Re: 2004 Turbo boost?
Yes, Silver is right! There is so much you can do to get HP from this cars that is not even funny!! I have a Turbo lite my self and I just install the air filter, the BOV and a racing wastegate. Im around 12 pound of boost right now until I get the Stage 1 that silver is talking about.
ROCKETMAN8060
Old 19 Jan 2010, 11:49 am
THanks for the quick replies.The cost for the CPU and 4 fuel injectors is $563. I don't have a labor cost yet.
Stu
PS. Are there any other worthwhile mods I should consider. I was surprised to see drum brakes on the rear, I guess thats how Chrysler keeps the cost down.This car actually out accelerates my 1993 Nissan 300Z up to 70mph.
Old 19 Jan 2010, 03:22 pm
Stu
I heard that 2004 turbos already come with the Stage 1 injectors! I still have to find more info about that. The instalation for the Stage 1 CPU is very easy, is a plug and play thing if you know what your doing.
ROCKETMAN8060
Old 19 Jan 2010, 05:20 pm
I just paid $153 for one injector for my 300ZX, so if I don't need the injectors I imagine it would cut the cost quite a bit, especially since the labor was another 315 to remove the manifold to fit them.
Old 19 Jan 2010, 06:24 pm
Well not exactly plug and play.
Stage 1 upgrade kit requires a dealership visit, or to order from Flight systems who input the mileage and VIN if I recall. There also needs to be a tranny learn procedure done. Lots of threads on this. Easiest 50 HP gain you can do.
It's true about the 2004 motor and injectors. You do not need to change them starting in 2004 and thereafter. The larger injectors come stock.
http://www.jegs.com/i/Mopar+Performa...10592/10002/-1
Dunno what labor would be involved. Order from FS, they put the VIN and whatnot in beforehand, you install it in the dealerships lot, slip the dude $20 to tell the PCM to tranny learn and do the procedure in the lot.
Old 19 Jan 2010, 08:44 pm
ChefTank's Avatar
Stage 0 upgrade kit requires a dealership visit, or to order from Flight systems who input the mileage if I recall. There also needs to be a tranny learn procedure done. Lots of threads on this. Easiest 50 HP gain you can do.
Mopar Performance P4510592 Mopar Stage 1 Turbo Upgrade Kits for SRT-4/PT Cruiser Turbo
best advice i have ever seen on this forum, serious!
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 22 Jan 2010, 09:30 pm
I went to the Mopar site I was given in the last note, but I/m confused because it says"577cc injectors for 2003 kit only." If there is anyone can definitely tell me whether I need bigger injectors on my "Turbo Lite" 04 would much appreciate it. Also some elucidation on the comment about the transmission relearning.
Thanks
Stu 88
more boost stock turbo wishbone83 General Turbo Discussions 0 06 Oct 2008 09:15 pm
Turbo Boost Taz_FL Turbo Performance 6 01 Jan 2008 08:25 am
turbo boost gauge. where to "t" it up? pppt03turbo General Turbo Discussions 3 24 Jan 2007 06:52 pm
Turbo XS Boost Controller With Adaptor blueberrygt Classifieds: For Sale/Trade 2 08 May 2004 06:08 pm
turbo boost sandylolee Turbo Performance 6 07 May 2003 06:05 pm
