Stainless Steel Flex Lines
Old 19 Jan 2010, 07:13 pm
Default Stainless Steel Flex Lines
Does anyone have or know where to get them? I can't find them any where...I would actually like to replace the whole brake system with Brembo or equilivent...I am told they don't make them for my Convertible 2005 Ot Cruiser
Old 19 Jan 2010, 08:47 pm
ChefTank's Avatar
Default Re: Stainless Steel Flex Lines
willywood, or willwood, or wilwood makes a big break kit for the PT. i "think" they are the only ones. be prepared to spend $800ish
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 19 Jan 2010, 09:10 pm
Thank you, I will check them out!
Old 19 Jan 2010, 10:36 pm
ROCKETMAN8060's Avatar
04-06-07 CHRYSLER PT CRUISER NON-TURBO F/R ROTOR + PAD : eBay Motors (item 280447964620 end time Feb-05-10 17:55:38 PST)
Take a look at this maybey this will help!!
ROCKETMAN8060
Old 20 Jan 2010, 05:18 am
Thanks, I will check itout!
Old 20 Jan 2010, 08:56 pm
ChefTank's Avatar
Originally Posted by ROCKETMAN8060 View Post
please dont buy these! or reccomend items you don't use/have not used. a friend bought these and they came in warped. nothing personal against you rocketman i appreciate your willingness to help.
Williwood makes a big brake kit for the PT. if you are sticking with the stock size rotor check out adam at That Rotor Shop he is also a member of ptcrew and makes zinc plated drilled and slotted ones. these have been tested on auto x and high speed slams by other crew members. you can get a full set for $250 and hawk pads will give you more than enough stopping power.
josh
50trim (2 Weeks)
Stage 3 (3 months)
Stainless Steel Brake Line pttuning Tech & Performance Forum 3 21 Apr 2009 07:29 am
Stainless Steel Exhaust Tip Cleaning Graveone The Detail Shop 5 30 Mar 2005 10:17 am
questions about stainless steel fender trim? legion Exterior Accessories Forum 4 22 Mar 2004 12:02 pm
Anyone Installed Stainless Brake Lines? Stephen R. Tech & Performance Forum 5 15 Sep 2003 01:58 pm
Stainless Steel Accent Bars mich_132003 Exterior Accessories Forum 3 01 Apr 2003 12:39 pm
