2006 PT Won't start when it's warm in the cab
Old 21 Jan 2010, 07:06 pm
Default 2006 PT Won't start when it's warm in the cab
Howdy,
I have a 2006 PT with about 46k miles on it. Its a standard and I notice that when I park it outside and it gets warm in the cab I have trouble starting it. Once it cools of it starts fine. I've even used some canned air to blow in the key hole and it start right up, at times.
This always happens when the car has been sitting for 4+ hours. When I park at work I park in a garage and the car cranks first time every time. Any hints?
I don't hear any clicks when it's trying to start, just turn the key and silence. It's not a consistant problem it crops up randomly, typically to my wife.
Old 21 Jan 2010, 07:13 pm
Default Re: 2006 PT Won't start when it's warm in the cab
Welcome to the forum.
Check battery cables - take them off, clean them, and re-attach.
Could also be ignition switch - try pushing in in key while starting....
Old 21 Jan 2010, 07:14 pm
I have tried pushing in to start and a few times that has helped. The battery is clean, it was the first place I went looking.
Old 21 Jan 2010, 07:22 pm
Be sure you can't move the cables - if they're loose, that'll do it.
Old 21 Jan 2010, 07:48 pm
If you can push it in and sometimes that will help it start, it sure sounds like an ignition switch problem to me.
2006 PT Cruiser GT won't start anglii General PT Cruiser Discussions 11 09 Apr 2014 03:50 pm
Air is blowing warm? enriquesoteloPT4 General PT Cruiser Discussions 2 21 Jun 2009 04:15 am
Warm A/C TaylorMade General PT Cruiser Discussions 5 12 Jul 2004 10:25 am
Warm Start issue? crazyjoe General Turbo Discussions 2 14 Feb 2004 05:31 am
Recommended warm-up time dbraveman General PT Cruiser Discussions 9 12 Feb 2004 09:38 am
