Transmission Failure help!!
Old 26 Jan 2010, 11:13 pm
Default Transmission Failure help!!
Okay here is my situation.... my 04 pt cruiser started making a little bit of a whirring noise upon acceleration, and I had recently been to jiffy lube for an oil change and they suggested i replace the automatic transmission fluid, so I went back and had that done. shortly after, I the car started taking a second to shift from gear to gear, then shortly after that it started slipping out of gear, then shortly after that it wouldnt go into gear at all. It broke down at a stoplight and I had to push it to the side of the road. After I had it towed home I discovered the tranny fluid was overfilled a bit. And I read on here that those transmissions require ATF+4, and on my receipt it just says regular ATF. Could putting the wrong fluid in and/or overfilling it cause it to go out? I heard the whirring noise before the flush, but it didn't have any issues till after.... could it be their fault? or could it have been going bad (hence the whirring noise) before and it just finally went out.... this all happened over a period of about 5 days, and 3 days since the tranny flush.....
Old 27 Jan 2010, 05:26 am
Default Re: Transmission Failure help!!
Fluid absolutely MUST be ATF+4 or you WILL have problems.
Old 27 Jan 2010, 06:07 am
Welcome to the Forum. Another reason NOT to go to a "QUICKIE" to have major work done.
Old 27 Jan 2010, 06:10 am
Correct.
Old 27 Jan 2010, 04:47 pm
How many miles did it have on it before the flush? Mine has 82000 on it and I have asked in another string if changing the fluid could cause it to go out. On some makes such as ford, it can. Please, more people weigh in on this.
Thanks,
Chuck
Old 27 Jan 2010, 08:21 pm
This is a group of Chrysler owners who have some things to say on the subject
moparts: ATF 4 versus Dextron III whats the difference?
Old 28 Jan 2010, 07:08 pm
Well they aren't claiming any responsibility for it.... Anyone know where to find a tutorial for pulling the tranny and replacing it??? and my pt has 110k miles on it before the flush btw, and it went out about 100 miles after the flush....
Old 28 Jan 2010, 08:09 pm
If it's the solenoid packs that went:
PTCrew.com - Learn it or Burn it.
And here's a write-up on better innards:
FM failure McRuss Sound and Security Forum 2 18 Jul 2009 07:12 pm
2.4 L turbo failure blackrain Turbo Performance 7 17 Oct 2006 11:04 am
tire failure lilhobo Southeast PT Forum 3 11 Nov 2004 04:25 pm
Engine failure GTCruiser2003 General Turbo Discussions 12 02 Jul 2004 10:32 pm
TURBO FAILURE! BUBBA-KONA General Turbo Discussions 24 21 Sep 2003 10:29 pm
