Brake symptom
Old 30 Jan 2010, 11:52 pm
bds02pt's Avatar
Default Brake symptom
My 02 PT's brakes just recently started acting funny. The break pedal has a pulsating vibration only sometimes when braking. The odd thing is that it also does (only sometimes again) when stopped. Put the car in neutral with breaks still engaged and vibration stops. Any suggestions? Was thinking maybe something with brake booster. Thanks for your help.
Old 31 Jan 2010, 02:41 pm
GaryCCR's Avatar
Default Re: Brake symptom
I'm not very pt savvy but the first thing I would check is the brake rotors just b/c it would be easiest, then my next guess would be the master cylinder but thats just a guess. Maybe check the vacuum line to the brake booster... Good-luck!
Old 31 Jan 2010, 08:22 pm
Symptoms of a warped rotor.
I'd just get new rotors, don't let them turn them - the rotors aren't think enough.
And don't buy the cheapest ones - try NAPA - they have more than one price - or Tire Rack.
Drum brake replacement Parking brake cable Dorkygrin General PT Cruiser Discussions 2 28 Mar 2009 07:53 pm
E-Brake careyk General PT Cruiser Discussions 1 06 Sep 2008 06:37 am
Symptom of dying thermostat? tony_perreault Tech & Performance Forum 6 14 May 2008 06:13 am
Brake kit milPT Wheels, Tires, Suspension 6 25 Feb 2004 01:50 am
E-Brake ptbruizer02 Tech & Performance Forum 11 23 Jan 2004 07:46 pm
