changed spark plugs...
Old 31 Jan 2010, 03:59 pm
Default changed spark plugs...
i replaced the spark plugs(champion double platinum) in my wifes 07 pt cruiser now i have a considerable decrease in gas mileage. i followed the go by on the forum but i did notice after a week of driveing that my brother in law didnt seat the map sensor all the way down on the intake so i fixed that...what made me look under the hood at things was the gas gauge was dropping much quicker than usual the weird thing was no check engine light came on that whole week. so after i fixed it the next day the check engine light comes on and i get a p0456 code (EVAP Control System Leak Detected (Very Small Leak) i reset it and it hasnt come back...car is running fine, no lack of power, no hesitations. any suggestions? should i just cough up the $100 and pay chrysler to put another set in..
Old 31 Jan 2010, 04:35 pm
Default Re: changed spark plugs...
Spark plugs do not effect mpg unless your plugs are bad and then you will see a drop in mpg. New plugs will only give you the mpg the car was designed for and nothing better. You do realize the dealer is totally ripping you off to change plugs. Here is a guide to changing plugs. It's pretty easy.
Spark Plug Guide
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 31 Jan 2010, 04:49 pm
that is the go by i used so if the spark plugs dont cause a decrease in mpg and i did not do anything else to the car what else could it be?
Old 31 Jan 2010, 06:40 pm
Make sure your Brother-In-Law didn't break off the tip of the MAP sensor so it isn't sending a bad signal to the computer. It's easily broken while pulling it out of the intake. That will cause your mileage to drop.
Old 31 Jan 2010, 07:10 pm
ok i will check that tomorrow is it easily noticable? if it is that where and how much to replace?
Old 31 Jan 2010, 07:31 pm
Ooops, I might have been thinking of the wrong sensor, although you'd better check that too. I was thinking of the IAT sensor on the air duck intake that goes into the throttle body. It was also probably taken off when the plugs were changed. It's on the hose on Step 4 of the Spark Plug Guide. There's a tiny blue bulb on the tip of the IAT sensor which can easily be broken off. If it's broken it can't measure the air coming into the throttle body and the wrong mixture of air and fuel will result. The MAP sensor is built pretty solid and there's not much chance of it being broken. It shouldn't have to be taken off the upper manifold either if the manifold is just lifted up to gain access to the plugs.
Old 31 Jan 2010, 07:41 pm
yea we realized that once we got started..that we could of left it on...i will check the other sensor tomorrow after work...any idea on that code? should i even worry about it??? the car is still under warranty till April so if it comes back i will just bring it to chrysler
Old 31 Jan 2010, 07:52 pm
9 out of 10 times that code means the gas cap wasn't tightened the last time you got gas but since you just had the manifold off, I'd look for something that wasn't back on correctly. There's a vacuum line I think on the right side connected to the upper manifold, check that plus the hose that's attached to the PCV valve also on the right side (as you face the engine). Check all over for anything that didn't go back on tightly.
Old 31 Jan 2010, 08:14 pm
yea i checked the gas cap...my dad said to spray around the lines with carbuerator cleaner to find a leak and the engine rpms will increase but i couldnt find anything...
Old 31 Jan 2010, 08:30 pm
You took off the intake manifold, right? Might have an intake leak - but usually that gives a rough idle.
Changed Plugs ejstith General PT Cruiser Discussions 16 16 Nov 2009 11:01 am
Just changed my plugs & wires... Travis2k7 Tech & Performance Forum 6 22 Jun 2009 09:16 am
Hard Misfire Under Load plugs changed karterfred Tech & Performance Forum 11 10 Jan 2008 07:10 am
Changed Plugs & Wires infernocruisr01 Tech & Performance Forum 4 30 May 2007 06:04 pm
Just changed plugs & wires gonzomania Tech & Performance Forum 2 04 Aug 2005 05:13 pm
