04 PT Turbo won't start
Old 01 Feb 2010, 03:39 pm
Default 04 PT Turbo won't start
my 2004 pt cruiser turbo had a Flashing MIL (OEM) light, then shut down driving down the road. will not start back up. will not jump start. will not turn over at all not even a click of the starter. if you turn it turn the car on to the run position it will turn all the gadgets on but will not start the car. any ideas on what could have happened to cause it not to start at all?
I tried the turn off and on 3 times thing to get a code and it will not give me a code at all, just the mileage shows up. Changed the Camshaft Sensor, that didn't do anything. Had to disconnect the battery to change the camshaft sensor, would this cause any codes to be wipped out of the system or is there still a way to get the codes?
Any help I can get is greatly appreciated. Thanks all.
My PT Won't Start Rdoggg1111 Tech & Performance Forum 57 01 Mar 2012 08:04 pm
04 PT Turbo won't start PTGal Turbo Performance 9 07 Jul 2011 09:52 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Need no start help for 04 turbo!! Kenroe Tech & Performance Forum 9 25 Jan 2008 09:03 pm
If you could start ALL over again .... onedivinehammer General Turbo Discussions 4 21 May 2003 08:13 am
