turn signals and hazzards
Old 07 Feb 2010, 04:51 pm
Default turn signals and hazzards
i have a slight problem; the turn signals and the hazzards on our 2001 pt cruiser dont work.
i have replaced the multi-function switch and the flasher module on the back of the switch.
i have checked all the fuses by the drivers left leg and they are all good.
any ideas or comments?
Old 07 Feb 2010, 06:15 pm
Default Re: turn signals and hazzards
Welcome to the forum. You have another set of fuses and relays under the hood. It's called the Power Distribution Center (PDC) and it's right in back of the battery. Part of the air filter has to be disconnected to reach it. The No#18 fuse is for the hazards. Try that.
Old 08 Feb 2010, 02:33 pm
thanks that did the trick, #18 was blown,
i found out that the new flasher unit was blowing them
sooo back in goes the old one haha
thanks again
but at lease the new multi function switch is working like it should
PT turn signals (or lack of) dgranros Tech & Performance Forum 6 05 Jan 2015 01:54 pm
turn signals AlexJB Exterior Accessories Forum 6 12 May 2008 08:12 pm
Help with Stealth turn signals toplessPT Exterior Accessories Forum 4 16 Mar 2005 10:43 am
Turn Signals Not Working Indynick General PT Cruiser Discussions 9 15 Sep 2004 02:25 pm
