Charging the Air Conditioner
Old 08 Feb 2010, 09:51 pm
Default Charging the Air Conditioner
I had to take my A/C hoses off to rebuild the engine.
What steps do I need to take to recharge it after reassembly? I was told that I need to replace the evaporator. Is this true?
Old 09 Feb 2010, 06:31 pm
Default Re: Charging the Air Conditioner
In a perfect world you would replace the accumulator, evacuate the system, meaning pull a vacuum on it for 30 minutes or so and then add freon. I don't always do things this way with my car and haven't had any issues over 20 years or so ... My 2
John but I did build this
Old 09 Feb 2010, 09:58 pm
Are you saying I might get away with just replaceing the "o" rings that I took apart, reconnect everything and charge it?
PS- The Porsche is awesome!!
Old 10 Feb 2010, 10:29 am
well,
You can but you risk having water in the system which can rust things. How often does this happen in modern systems I don't think much. If you have the extra cash to spend do it . I on the other hand the system is made much of aluminum mixed with oil not much of a rust friendly environment.
I am sure the manual will state otherwise, again its your call ...
Old 14 Feb 2010, 01:12 pm
Matt42's Avatar
You don't need to replace the evaporator. It's a good idea to replace the accumulator, sometimes known as the receiver-drier. Where are you? Some list members have A/C vacuums and can help.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 16 Feb 2010, 09:54 pm
I am still in the process of putting this together but I am in Red Oak, TX.
Thanks alot!!
Chuck
Old 17 Feb 2010, 09:49 pm
767skyking's Avatar
I'm not sure about Texas, but in California, Autozone will rent the pump for free. (They just take a deposit)
Old 19 Feb 2010, 09:19 pm
Well, Autozone don't loan them out in Texas but I will check everywhere around until I find someone who does. I have used quite a few loaner tools but I had no idea that you could get a loaner A/C vacuum. Thanks for the info!
Old 19 Feb 2010, 09:59 pm
I know this may sound odd but if you find an old refrigerator around the pump inside the unit makes a great evacuator. Takes a little work to remove, wire and fit the hose fitting but it's cheep..
Old 20 Feb 2010, 11:05 am
Matt42's Avatar
D'Oh. That should work, maybe a little slow, but certainly cheap. A key to it working is that the compressor can't be seized up, though.
charging problems with 01 pt cruiser gdxxman General PT Cruiser Discussions 3 11 May 2009 04:59 am
UK crd charging question spiceweasel Tech & Performance Forum 6 15 Dec 2007 04:37 pm
Looking for charging system mods oldcoach General PT Cruiser Discussions 0 27 Oct 2007 05:16 am
Blown Gear box after Turbo Charging Kboom General Turbo Discussions 4 27 Oct 2004 05:38 am
Super charging Mr.Blonde Turbo Performance 7 29 Apr 2003 10:31 am
