Power locks don't work
Old 09 Feb 2010, 04:55 pm
Default Power locks don't work
I have a 2002 limited cruiser and for some reason the power locks don't work. Neither does the keyless entry remote. We've replaced the fuse under the dash and that didn't help, we looked in the fuse panel under the hood and it doesn't show a fuse for the locks.
when I turn the lights on the little green light on the door lock button lights up.
What could possibly be wrong?
Old 09 Feb 2010, 05:48 pm
Default Re: Power locks don't work
Welcome to the forum, again.
The power locks work from the RKEM (Remote Keyless Entry Module) located in the dash. Here's where.....
You said you checked the fuses in the PDC (Power Distribution Center) that's located in the engine compartment. The No# 10 fuse is for the RKEM and it might be your problem.
The little green light is supposed to light up whenever the headlights are on. Chrysler did away with those lights in latter years. They are there to help you see the lock/unlock button at night. They have nothing to do with the workings of the lock.
Old 22 Feb 2010, 01:50 pm
Thanks for the diagrams ^_^
On my fusebox under the hood it doesn't show anything on the layout of power door locks being there. Do you think it may be a different lid?
We are still having trouble with the alarm going off randomly now when all the doors are shut and it goes off when you open the back doors.
Old 22 Feb 2010, 04:39 pm
The layout of fuses under the hood is listed in the owners manual, not on the lid.
Why your alarm is going off, I can't answer.
Old 23 Feb 2010, 04:05 pm
Thanks for all the help, we went to the junkyard and got one of those boxes from a wrecked PT for 40$ and it works amazingly now. I'm so happy it was just that.
Thanks again.
Old 08 Aug 2013, 01:17 pm
CREWSIN.......... I seem to be having a problem with my door locks not working. The switches on the door panel don't work at all. The remote ONLY works with the light turned on. Do my symptoms also seem to point to the RKEM? I've checked ALL my fuses under the dash and under the hood and they all check out good. Your thoughts?
Old 08 Aug 2013, 05:17 pm
randyincctx's Avatar
Lightbulb Re: Power locks don't work
Your saying all 4 door lock switches don't work? (2 doors for convertible PTs),and neither does remote?........It sure sounds like the RKE module,which is located under the center of the dash(exposed to alot of heat from the sun).....A new/used RKE module may correct the problem with the switches,but if you only have 1 remote(you need 2 to program them to the RKE),you will need to go to a dealer to have them use a DRB III scantool to get the remotes to work with the new/used RKE module;I have the exact problem,and I found a replacement (used) RKE on Ebay for $48.97 (not bad at all) considering the dealer wanted $268.00 for one!!!!!......I also purchased a new remote for $14.88 also on Ebay (I need to get it programmed) because I had the exact problem your experiencing......My local dealer said they charge $70.00 to program my remote to the RKE......But,with a replacement RKE your will have the switches,key functions,and even the speed sensitive door locking feature....Just NO remote function,till you get them programmed,and the dealer is the only one I have found that has the DRB III scantool....They cost anywhere fron $4,000(used) to $8,000 (new)
Aka:~KILLER~
Old 08 Aug 2013, 06:09 pm
Thanks Randy! All things considered, I think I'll just leave like it is given the expense. Thanks Again!
Old 08 Aug 2013, 06:57 pm
Well,if you change your mind here's a reasonable one for sale on Ebay for $59.99+Free Shipping: 02 08 Door BCM ECU PT Cruiser Door ECU Keyless Entry 5293040AH H | eBay (Your door lock switches & keyed features should work again,and that price is about $200+ less than dealer wants;Also takes about 30 minutes to install.)
Aka:~KILLER~
Old 06 Mar 2017, 01:56 pm
I have a 2001 PT Cruiser, Limited Edition...and the power locks work intermittently with the Fob. So basically, it doesn't unlock any door. When this happens and I use my actual key to unlock the doors, I have to hold the key to the Unlock position or else even the key won't unlock the doors. My fob tends to be ineffective mostly during high humidity. Anybody have a direction?
02 power locks dodgeing734 Tech & Performance Forum 3 05 Aug 2009 06:45 pm
Power locks not working! JHCT General PT Cruiser Discussions 1 30 Nov 2008 04:03 pm
Power Locks wedge22 Tech & Performance Forum 8 29 Sep 2008 11:43 am
power locks ptlvr Sound and Security Forum 3 09 Apr 2008 06:15 am
power door locks deederz Interior Accessories Forum 6 22 Feb 2006 06:23 pm
