=( stuck with overheating issue
Old 10 Feb 2010, 03:31 pm
Default =( stuck with overheating issue
Im new to the forum but i have read most post on over heating as a guest.... when it started it was leaking from the thermostat housing replaced thermostat an gasket,flushed the radiator, new cap and burped it... it over heat when driving with windows down ( fan has both speed working) when stopped it starts cooling down ..... please help im stomped with it ......
Old 10 Feb 2010, 04:51 pm
Default Re: =( stuck with overheating issue
Other causes -
water pump going bad
Clogged radiator
Head gasket.
How many miles? At about 10,000 need new timing belt and water pump.
Look at coolant and oil - clear or cloudy? Cloudy is a head gasket sign.
When cool, look take off radiator cap and look in for gunk buildup.
Also try replacing the radiator cap - cheap and can't hurt.
Old 10 Feb 2010, 05:07 pm
Thanks im leaning towards the waterpump my self seems like hell but not sure ..
Old 10 Feb 2010, 05:45 pm
How many miles? At about 100,000 need new timing belt and water pump.
Old 10 Feb 2010, 06:37 pm
From what I've read and heard from different owners, if the PT overheats at highway speed and cools down when stopped, the problem should be a clogged radiator or blown headgasket. Just my $.02
That's just the opposite of overheating when stopped which is more likely the fan.
Old 10 Feb 2010, 06:44 pm
the PT has 86,709 miles on her it was my Grandmas car an she always took it to the dealer for its scheduled maintanice
Old 10 Feb 2010, 06:45 pm
Originally Posted by quicksilverdon View Post
Other causes -
Clogged radiator
Head gasket.
Have to agree with you this time. I would lean towards a bad headgasket and or warped head.
Old 10 Feb 2010, 06:47 pm
OK im with 100%, but i flushed the radiator an the oil isnt milk shake!!
Old 10 Feb 2010, 09:29 pm
Well since it started with a leak and that was repaired, maybe its got an air pocket. Some times the simple things are missed. Especially when your not a trained tech.
Old 11 Feb 2010, 10:12 am
I realize that this problem started with a leak, but it is possible that another problem has just popped up at a time that makes you lean towards the leak as being the culpret.
Check the lower radiator hose while the engine is cool. Work your way from one end to the other by squeezing it. Sometimes a soft spot will weaken in the hose and while hot and accelerating the water pump will increase the suction on the hose causing it to collapse and shut down the water flow. When you come to an idle, the water pump slows down allowing the hose to relax and letting the water/coolant flow normally again.
Please keep us informed.
Very unique overheating issue (I searched threads, no luck) Munkeyboy Tech & Performance Forum 10 22 Jul 2010 11:09 am
stuck in denver careyk General PT Cruiser Discussions 8 21 Dec 2009 09:02 pm
Stuck in the mud Andre General PT Cruiser Discussions 9 29 Oct 2009 10:11 pm
stuck thermostat? supgrrl General Turbo Discussions 4 01 Oct 2009 07:41 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
