check engine light
Old 13 Feb 2010, 04:21 pm
Default check engine light
About a week ago I drove 150 miles to visit a friend. Just before i started out I filled up the gas tank. When I got to where I was going I noticed that I had not put the gas cap back on. I never saw the gascap warning and the check engine light was not on. I few days later I again filled up the tank and drove another 150 miles. The next day the check engine light was on. I pulled a code, p0445 (Evaporative Emission Control System Purge Control Valve Circuit Shorted). Yesterday I drove it home and the light was still on. I did the key dance again, and there were no codes...but the check engine light was still on. Will the check engine go out by itself,or do I need to take it somewhere to have it fixed?
Old 13 Feb 2010, 05:14 pm
Default Re: check engine light
Disconnect the negative battery terminal on the battery for 20 minutes, that should fix it....
Old 13 Feb 2010, 06:17 pm
You can go to Autozone, etc, and they read codes - I suspect they'll clear it for you.
It will eventually go off by itself after so many starts.....
Old 13 Feb 2010, 11:45 pm
Thanks Don...sounds like a good plan.
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 13 30 Apr 2012 04:49 pm
Check Engine Light Yellow PT General PT Cruiser Discussions 6 23 Jul 2010 02:57 pm
Check Engine Light On vicky52 Tech & Performance Forum 11 23 May 2009 01:23 am
check engine light ccprez Testing 12 16 Mar 2008 08:22 am
Engine Check Light IRPT Tech & Performance Forum 11 27 Jun 2004 10:24 pm
