HEAD , Hd Gskt, Valves warped among other things
Old 15 Feb 2010, 03:29 am
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Exclamation HEAD , Hd Gskt, Valves warped among other things
Okay I had a biggg problem with my PT.. It started overheating .. No issues before, just bammm... Well my themastat was stuck, so I poped it out buttoned it back up and went on my way. Well that was problem 1 of many.. It ran for my wife fine in the morning, but as I went to head to the bank , it would not start.. Uhhhh , so into the shop it went. They tell me the radiator was half clogged only allowing the fluid to cool in one half of the chambers and running hot in the other.. It is replaced along with a new themastat and I was told it is fine and you are good to GO. They ran tests for compression and all that other good stuff for heads..YEAH.. I will never believe that again.. Turns out they were freaking wrong.. Head were warped, headgasket was bad, needed a valve job among other things. Lets just say I received a major discount along with new water pump and timing belt and now I have pretty much a new heart for my PT.. So my nightmare is over, I have it back and ready to get my customizing on ...
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
Old 15 Feb 2010, 12:34 pm
Matt42's Avatar
Default Re: HEAD , Hd Gskt, Valves warped among other things
PLEASE don't say that they put in Dex Cool. I think that your year calls for the Magenta HOAT coolant. Dex Cool will clog up your system again in short order.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 15 Feb 2010, 12:46 pm
So, New raidator, new timing belt (and I hope, new water pump & tensioner), redone head - you're good for another 100,000 miles.
If you have an auto, get it flushed (flushing machine) and be sure they use only ATF + 4.
Valves and Pistons fljohnboy General PT Cruiser Discussions 2 21 Jul 2009 12:35 pm
blow off valves (smog ok?) paulscrazed General Turbo Discussions 4 11 Feb 2008 05:48 pm
i think my rotors are warped - are yours? pppt03turbo General Turbo Discussions 12 25 Dec 2005 03:59 am
Warped rotors mgrantom Wheels, Tires, Suspension 4 05 Aug 2004 08:15 am
Oil drain plug valves gonzomania General PT Cruiser Discussions 6 28 Jul 2004 01:35 pm
