bypassing air conditioner compressor?
Old 15 Feb 2010, 03:24 pm
Default bypassing air conditioner compressor?
Ok, The '03 PT that my brother got over the weekend has been sitting for approx. 14 months. he threw a new battery in it and it started right up, then it started smoking until the belt broke. Now it doesn't have power steering, or air. anyway, my guess is that the compressor is frozen... can you just bypass the compressor, and just have power steering (he is still in college and doesn't want to spend a ton of money)?
I did this on my cavalier by just going to autozone, and told them i wanted a belt for the cavalier w/o air conditioning and then just didn't wrap it around the compressor.
He is going to bring it over next week to start working on it in the garage, so i will have a better idea then of what is going on. any one have any tips or tricks or advice for a new PT owner?
Old 15 Feb 2010, 04:50 pm
Default Re: bypassing air conditioner compressor?
I'm not a mechanic but looking at the belt routing (compressor on bottom right) I don't see how to bypass the compressor.
Old 15 Feb 2010, 04:59 pm
so they moved something for the non-AC models? (I saw belts for non a/c models on autozone's website)
like i said not sure which one is froze, but at least one pulley is. and i should have a better idea next week.
thanks.
Old 15 Feb 2010, 05:19 pm
Sorry, don't know. Maybe they have a no-nothing pulley to take the place of the compressor.
The belt at Autozone is 51.5 inches without A/C, 55 inches with A/C, so maybe they did put a small pulley in place of the compressor.
Old 20 Feb 2010, 03:20 pm
ok, got the car here, and found out that the compressor pulley is very hard to turn. took the clutch off and I am now unable to remove the pulley.
Is the pulley replaceable?
is there a puller that you use to get the pulley off?
the center part of the clutch spun no problem, so the compressor should be fine, i think its just the bearings in the pulley.
Old 20 Feb 2010, 04:54 pm
Ok, got the pulley off...
pulley is slightly dented, it was stuck on there pretty good. so it looks like I will need a new A/C clutch and pulley assembly? any good suggestions?
Old 20 Feb 2010, 05:24 pm
I'm not sure if you can get the clutch by itself.... If so then that sounds like the way to go. If you can turn the compressor then you are good.
Old 20 Feb 2010, 05:52 pm
Haven't bought for the PT, but used to be able to buy just an A/C clutch.
Old 21 Feb 2010, 08:47 pm
Why not try to get a junkyard a/c compressor?
You don't even need it to work just to have a good pulley.
A compressor on an engine removed from the vehicle and exposed to the elements should be cheap.
Old 14 Nov 2017, 03:57 pm
i can confirm that there is way to bypass ac compressor on 2001 pt cruiser 2.4L: engine
not sure how they did it becasue i cant see in engine well but i can see that there is no belt around the ac pulley and vehicle operates ok.
ac relay was also removed
this was all down by previous owner
AC Compressor rfsexton Tech & Performance Forum 2 05 Dec 2009 08:04 pm
AC Compressor for 01 mrcarlosmorales General PT Cruiser Discussions 2 15 May 2009 01:24 pm
AC compressor rickmancc Classifieds: Want To Buy 0 10 Jun 2008 10:55 am
ac compressor gail Tech & Performance Forum 2 07 Aug 2003 04:47 am
Air Conditioner Compressor PT 7 General PT Cruiser Discussions 5 24 Jul 2002 06:40 pm
