I have a 01 pt crusier limited edition that i had an oil change done and afterwards i noticed a knocking noise. I brought it to the dealer and they told me i needed a new head gasket and spark plug seats have 92k on the engine so told them to do it. picked the car up on friday and it was still making a knocking noise but not as bad. car sat on the weekend. on monday drove 15 miles to work. on my way home about 6 blocks away from work the engine stalled no loud clank just stoped running and would not start up again. so i had it towed back to the dealer and they told me the #1 pistion smacked the bottom of the sparkplug and shatterd it. they said i need a new engine. what could cause that. could the dealer done something wrong. thank you
Even with the timing belt breaking, the valves don't hit the pistons, and in worse case, the valves can hit each other. Nothing to do with the plug hitting the top of the piston. Only thing I can think of is a longer threaded plug being put in but that should start hitting the piston as soon as the engine starts, not after a 15 mile drive to work and back.
Possibly a piston pin starting to give way (knocking sound you heard) and when it finally gave way it allowed the piston to go further up the cylinder than it was intended to do and then smack into the tip of the plug. Last edited by CREWZIN; 16 Feb 2010 at 09:46 pm. |
I don't see how the piston could hit the bottem of the spark plug unless something else was wrong. The pistons travel the same distance every stroke and the spark plugs are stationary. Unless the piston rod came loose allowing the piston to travel up in its bore farther, or the spark plug was extra long allowing it to go into the head deeper, I dont see how this could happen unless the car was mis-diagnosed in the first place meaning that you had a loose rod which would explain the knocking noise which would not be corrected by replacing the head gasket, leaving you with the possability of throwing a rod which could definately drive a piston into the spark plug.
Isn't that what I said?
You had your head gasket replaced and spark plug seats ?? I'm thinking something is not being explained correctly.. Now if you had your valve seats replaced I can see how one of them can hit your piston. Ether way I would suggest another opinion. You need someone who can look this over who ass isn't on the line. I would say your dealer screwed up and isn't steeping up. IMO
Sorry Crewzin,
I am a slow typer or maybe thinker. I probley started my reply 10 minutes before you did and finished about 10 minutes after you!! ![]() |
![]() Quote:
A knocking noise after an oil change, especially at a place like a spiffy lube, often means that they forgot to put in the new oil. Question for Rich 228: Was that a Chrysler dealer you took it to?
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring |
Thread Tools | |
Display Modes | |
Need some advice-Problems with my replacement engine | Abgmauldin | Tech & Performance Forum | 11 | 16 Feb 2009 09:14 pm |
2002 PT Cruiser engine problems | bastropcruiser | Tech & Performance Forum | 2 | 11 Feb 2009 08:54 pm |
Engine Mount Problems | chris1916 | Tech & Performance Forum | 1 | 15 Jan 2009 03:19 pm |
Engine Replacement problems | LatinPhilo | General PT Cruiser Discussions | 7 | 28 Oct 2008 11:12 am |
the engine light - but seems no problems | Victoria | Tech & Performance Forum | 5 | 25 Feb 2005 10:46 am |
