Picture of assembled engine
Old 16 Feb 2010, 08:10 pm
Default Picture of assembled engine
I am installing an engine and I'm really not well versed on the PT engine. I did remove the engine but that was more than 5 minutes ago and I've forgotten all that. LOL I have the basic short block together with the T belt and covers on as well as the intakes.. I just am looking at a huge pile of parts (from two engines) and need a refresher
Old 16 Feb 2010, 11:24 pm
Default Re: Picture of assembled engine
I was able to cobble it together without a picture, I guess I will need to brake it down before installing ????
Old 17 Feb 2010, 06:30 am
That's an '01 or an '02 engine, because it has EGR.
Old 17 Feb 2010, 08:30 pm
That was helpful
Old 17 Feb 2010, 09:39 pm
767skyking's Avatar
Driveability...
After talking to my Chrysler Tech friend, they remove and install from the bottom. I believe the engine can be installed as the picture shows except for the exhaust manifold. Do you have access to a lift?
Old 17 Feb 2010, 11:37 pm
Originally Posted by 767skyking View Post
Driveability...
No lift but I can get the front end up quite a bit. That's how I remove and install my SBC V8 in my Porsche 914. I'll have to take some measurements. It would be nice to install the engine together but thanks for the information. I removed the engine from the top but had to remove everything but the cylinder head.. and still it was a bit tight. I'll be installing the engine tomorrow. I'll post some picks..
Thanks !
Old 22 Feb 2010, 02:04 am
I spent some time installing the engine, lots a little parts all stuffed in a small space LOL. Fired it up and it ran well, i have to make sure everything is topped off tomorrow. Sounded good, there is a small exhaust leak at the flex joint in front of the cat converter. Looks like I can weld that, however I don't know for sure. I will test drive it tomorrow a bit. Wish me luck
Old 23 Feb 2010, 08:21 pm
Got it running today and everything looks good. I was able to put 100 miles on the car today with no issues, runs nice, transmission shifts good as well. The engine removal and re-assembly was a lot of work but worth every bit..
need picture of engine specifically the timing belt wendykey Tech & Performance Forum 19 02 Aug 2010 10:54 am
My PT in a Picture bigslim General PT Cruiser Discussions 2 07 Aug 2006 01:02 am
A picture proxeyed General PT Cruiser Discussions 6 23 Mar 2005 10:14 pm
Looking for a picture Taz_FL General PT Cruiser Discussions 8 03 Sep 2004 12:36 am
New Picture Jimbo General PT Cruiser Discussions 12 17 May 2004 02:26 pm
