engine won't run
Old 17 Feb 2010, 08:03 am
Default engine won't run
The engine light stated to come and blink periodicaly, did new plugs/wires,mech said code showed misfie on #4-then died..changed coil,checked timing/belt, replaced cam sensor, now says needs comuter but says w/need to be programed.... any suggestions? HELP
Old 17 Feb 2010, 08:39 am
Default Re: engine won't run
Welcome to the forums.
It's possible....
read similar:
2004 PT Cruiser Wont Start
Old 18 Feb 2010, 06:26 pm
I was a tune up drvieability guy for years and have had thousands of cars that wont run.
After checking for codes I would do some quick tests, first would be if it would crank I would key it up and listen for the fuel pump and the quality of the tone it made.. That tells me among other things the computer is up and smart enough to turn that on.. Crank the engine and listen to the crank rhythm, listening for the presents of compression being made. An engine with a bad timing belt will likely crank much smoother and have a different rhythm. If all that sounds good I would pull off a plug wire off a coil and look for spark, good quality Zap ! If that works than a check of the injector pulse.. If everything works good than look for something like diesel fuel in the mix. things in that area.... seen that dozens of times.. I'm sure your fuel is good LOL
HST I think your Tech is week and having trouble making a correct diagnosis and that's costing you money !! Sad but true not everyone knows what there doing and work at a high level.
Quick thought, Most EFI systems (Remember Most) don't blink its service light randomly. I mean that they don't flash on and off without some pattern. If your light is doing something odd like this it could be a computer issue , but power inputs and grounds will do the same thing..
Old 19 Feb 2010, 12:21 am
Thanks for such a detailed run thru. Can a non-dealer pin-point a computer problem first? Weel, a new computer on order now. Will let you know how it works.
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
Engine lurcing + engine lite come up on 05 GT Roadmaster General Turbo Discussions 11 18 Apr 2009 01:10 am
Which engine do i have?? b0b88 Tech & Performance Forum 13 14 Feb 2009 12:06 am
2.4l engine. PTucker Turbo Performance 16 12 Dec 2003 08:50 am
N/A Base Engine vs Turbo Engine Kirby General Turbo Discussions 7 02 Oct 2003 01:42 am
