car won't start, goofy sound
Old 20 Feb 2010, 07:26 pm
Default car won't start, goofy sound
After all the snow, I was finally able to get to one of the cruisers and it won't start. However, the starter is clicking, but the engine won't turn over. All interior lights, fan, radio work. When I turned the key off, all the instrumentation panel lights and interior lights start going nuts until I step on the brake. That's what I have to do to stop the remote starter if I have used it. The remote starter hasn't worked for months. Could the battery be low on amps? I haven't changed the battery since I've owned the car (more than a year).
This is the same cruiser I have been fighting the misfire problem on. I really need to get this thing running to get it to the shop.
Thanks.
Jeremy
Owner of Bessy, '02 Limited Steel Blue & Gidget, '02 Limited Blue Woody
Old 20 Feb 2010, 07:53 pm
Default Re: car won't start, goofy sound
Clicking sound is a sure sign of a battery that needs charging. The starter takes more power from the battery than anything else so you need around 11.8 volts. The horn, lights and other accessories might work on the lower voltage but the starter won't have enough power to turn over the engine.
Old 21 Feb 2010, 12:42 pm
Agree. Either jump it or charge the battery.
Old 21 Feb 2010, 01:28 pm
rkagan's Avatar
happen to me last week also... it was the battery... replaced it and works awesome now!!! and jumping didnt help to keep my battery good...only gets it started and stopped at the next place.
Old 21 Feb 2010, 05:32 pm
didn't bother with jumping...I've never had good luck with the goofy charging post. I just bought a new one and it runs now. Remote starter works, too. Battery I took out was from 2006. Now I have to tackle an overheating problem! There was little to no coolant in res. I may still have a thermostat or water pump problem, but at least I'll know where to start.
Thanks.
Jeremy
Old 21 Feb 2010, 08:21 pm
Don't forget to bleed the air out of you system. Bleeder valve is below the thermostat housing.
Old 21 Feb 2010, 08:50 pm
I think your suggestion about bleeding the air out of the system is a good one BUT we're talking about replacing the battery, not the radiator.
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
goofy code jdmickies Tech & Performance Forum 5 03 Nov 2009 10:46 pm
No sound Help please. demon666 Sound and Security Forum 4 17 Aug 2009 05:36 am
Clank sound on Start up DaShado General PT Cruiser Discussions 2 01 Jul 2007 11:11 pm
Monster PT mods, and other goofy ideas PTGT-NH General PT Cruiser Discussions 2 07 Jun 2003 04:02 am
