2005 engine into a 2001?
Old 20 Feb 2010, 07:58 pm
Default 2005 engine into a 2001?
Has anyone tried it? I tired doing a search fort the differences between the two but the results did not give me what I needed to know. From what I can tell so far the 2005 was lacking EGR, simple fix was to swap the parts over from the 01 engine. Beyond that it looks like the crank position sensor is in a different spot and the camshaft has a different number of magnets in it for the cam position sensor.
The biggest question is can the 01 computer run this engine? Someone else bolted the motor in the car and I got the task of cleaning up what was left behind.
any help would be greatly appreciated
Old 20 Feb 2010, 08:43 pm
Default Re: 2005 engine into a 2001?
See if this gives you any information:
2001 Engine swap
Old 21 Feb 2010, 12:30 pm
Welcome to the forum.
Clearly if you replace problematic parts with '01 parts, the computer won't know the difference.
Old 21 Feb 2010, 03:16 pm
It will not work. The main issue id the crankshaft tone wheel. The 01 and 05 have major differences. Different # of teeth. Also the 05 head does not have provisions for egr.
Old 22 Feb 2010, 10:34 am
That is everything I needed to know right there. Although someone did manage to bolt the egr valve to the 05 head
2001 & 2005 cooling fan issue ptcruiserdad Tech & Performance Forum 12 03 Jul 2011 07:26 pm
2005 Engine Cover? PTZee Tech & Performance Forum 2 06 Sep 2009 08:59 pm
engine from 2005 to 2002 bartekzloty Tech & Performance Forum 10 04 Sep 2009 10:10 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
2001-2005 hood Goddess kit for sale teachtheart Exterior Accessories Forum 1 10 Dec 2008 09:16 pm
