What spark plugs have been tried and trued for a NA PT???
Old 21 Feb 2010, 07:20 pm
Send a message via MSN to Ironman
Default What spark plugs have been tried and trued for a NA PT???
As the title states, I ran Bosch Platnum 4s when I first bought the car, they worked well, but I heard some horror stories about them burning so hot they caused piston damage. Last time round I ran the stock spec Champions and was not impressed. So what have people used to give them better gas mileage and acceleration?
Hmm, perhaps I should have changed this to the ultimate tune up thread.
I need to replace my air filter and spark plug wires as well. I used Crane Firewires with good results, but I can't find them anywhere for a reasonable price. And I have just been using Fram air filters. Any other suggestions for somebody looking for a little extra gas mileage and performance on a budget? (pertaining to these three components only please)
Non Turbo, Automatic Transmission 2003 Touring Edition, 104,xxx miles so far. Extras- cruise control, fog lights, sun roof, rear defroster, ABS, rear disk brakes, six speaker sound system, power locks, power windows, A.C., window tint, locking glove box. My personal mods so far- removed white air restricter, white hibiscus flowers sticker above the rear hatch lock, nice white primer/rust splotch underneath the passenger side tail light from bodywork...more to come once the money starts flowing freer and the car is payed off
Old 21 Feb 2010, 07:51 pm
Default Re: What spark plugs have been tried and trued for a NA PT???
Champion Double Platinum #7570 plugs
K&N filter
Granatelli Performance Ignition Wire Set
Old 21 Feb 2010, 08:59 pm
The company that manufactured Crane wires went out of business. As Crewzin said, Granatelli's are the ones many have used since.
Old 21 Feb 2010, 09:05 pm
Dino's Avatar
I'm putting my Granatelli's on this week along with Denso Iridium power plugs and a drop K&N filter. The Granatelli's aren't cheap and I haven't tried them yet but they are some well built wires I was totally impressed with the feel and look of them. I was comparing them to my stock ones still on the car and they look like toy wires compared to the Granatelli's.
Old 22 Feb 2010, 07:01 am
Nothing wrong with the stock copper Champions - many use them on hopped-up turbos with fine results.
For a non-turbo, gap at 0.040.
Platinum or irridiums will last longer, but if you want to feel a spark plug change you'll be disappointed, unless your existing wires/plugs are bad.
Old 22 Feb 2010, 11:12 am
Wow, those Granatellis are spendy, anything in the $50.00 range??? And what about air filters? I eventually want to do a CAI on this thing, so spending money on the K&N drop in just seems like a waste of money. Anyway, has anybody had issues with the Bosch platinum 4s??? Those seemed to give me a bit of a boost in performance.
Old 22 Feb 2010, 02:39 pm
Totally true.
I'll put my $50 MSD wires that I use on my 12 second SRT-4 Neon up against the more expensive Granatelli's any time.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 22 Feb 2010, 05:53 pm
Dino's Avatar
Originally Posted by Mean Green View Post
Totally true.
That would only be fair if you raced yourself first with one set and than with the other installed.
Old 22 Feb 2010, 06:01 pm
Old 27 Feb 2010, 12:07 am
Personally I've had lousy luck with Bosch Platinums on anything I've used them on.
I put iridiums in my cruiser last year. Stock wires.
I had a #1 cyl misfire last fall that caused an intermittent idle shake.
I moved plug wires and coils to see if the problem followed. Still #1 missfire. Switched plugs on the same coil to see if the problem followed the plug.
Misfire went away and has stayed gone. Apparently one of the plugs didn't like firing backwards (waste spark system).
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
Spark Plugs voblak2 Tech & Performance Forum 1 10 Sep 2008 12:47 pm
Spark Plugs jingks Turbo Performance 6 31 Jul 2008 10:28 am
Best spark plugs pastorj651 Tech & Performance Forum 6 26 Jan 2005 09:33 pm
Spark Plugs kidturbofan Turbo Performance 2 08 Oct 2003 10:40 pm
