Removing timing belt cover hell ?
Old 22 Feb 2010, 02:09 pm
Question Removing timing belt cover hell ?
PT CRUISER 2.0 2002
After looking at the step by step instrutions for timing belt change (sticky) Everything was going ok until i removed support bracket bolts (18) but cannot get the support bracket out due to not enough room ?
I have tried supporting the car /engine all different ways
any advice would be appreciated
regards john
Old 22 Feb 2010, 04:51 pm
Default Re: Removing timing belt cover hell ?
John,
Hopefully you have a 2.4 ltr engine and not the 2.0 as you stated. The instructions are for the 2.4 U.S.A. model cruiser. The 2.0 is made overseas and I believe is a diesel so things will be different.
Old 23 Feb 2010, 12:45 pm
Thanks for the reply
we are in uk.
The crusier is 1995cc petrol model dated 2002
we have tried lifting the engine to the extent that the car starts lifting
All bolts out of engine mounts etc.
Is the timing cover in 2 halfs as we cannot get it off ?
see pic attached
thanks
john
Old 23 Feb 2010, 01:22 pm
My repair manual covers the 2.0 and the 2.4 engines. On yours it says to remove the two lower and single upper timing belt cover bolts. So it sounds like you have a one piece cover.
On the 2.4 engine it says to remove the upper and lower timing belt fasteners and then remove the "covers" so we have two pieces.
timing belt Thomas1 Tech & Performance Forum 20 21 Jul 2012 09:06 am
Timing belt what a JOB!! 02PT Tech & Performance Forum 6 08 Dec 2009 06:31 pm
weird rattle under timing belt cover jdmickies Tech & Performance Forum 12 04 Nov 2009 09:39 am
timing belt help bowtie_65 Tech & Performance Forum 2 29 Nov 2008 02:12 am
Timing Belt notadodge Tech & Performance Forum 11 25 Nov 2008 09:37 am
