P0304 code Engine Light On
Old 22 Feb 2010, 11:18 pm
Send a message via Skype™ to wedge22
Default P0304 code Engine Light On
I just used the 3 turn ignition trick to find the code and then the handy code guide in this section to determine what it was. My PT has been intermittently flashing the engine light and then it would go off again a day or so later. I am guessing that I really need some new spark plugs as they have not been changed and the car has 35000 miles on it now. Would you suggest any other work while this is being done, it does get regular oil changes.
PT Cruiser my first car in nearly 3 years
Old 23 Feb 2010, 07:02 am
Default Re: P0304 code Engine Light On
Yes, change the wires as well as the plugs.
MSD, even Autolite wires are better than the stock wires.
If you PT is not a turbo, gap plugs at 0.040 - smaller if it's a turbo.
Check engine code P0304 Gary Mick Tech & Performance Forum 28 04 May 2014 06:26 pm
Check Engine light code help sohc1996 Tech & Performance Forum 8 30 Sep 2012 07:36 pm
Engine Light on P0139 code shutterbug Tech & Performance Forum 6 25 Sep 2011 05:49 pm
Check engine light on - can't get code Pinkbadge Tech & Performance Forum 5 10 Apr 2011 07:01 pm
Error Code P0304 Max Tech & Performance Forum 2 30 Mar 2009 03:46 pm
