multi function switch problem
Old 22 Feb 2010, 11:25 pm
Default Light problem NOT THE SWITCH
New member here, I have the fortune of being the family mechanic while I am at home, and my parents '03 GT has a problem with the lights. I did a search and couldn't find an answer to my question. Occasionally, the switch will turn on the head lights, but the dash lights and outside marker lights don't come on (aka daytime running lights-ish) The fog lights and turn singals work, and there are no other related issues.
2003 PT GT turbo Limited, auto, fully loaded, 71k miles.
Thanks for your help!
EDIT: I just installed a new multi-function switch and that did not cure the problem. Are there any grounding issues with the lights I don't know about?
Old 23 Feb 2010, 07:44 am
Default Re: multi function switch problem
Welcome to the forums.
Have you read threads on the mutli-function switch?
All different symptoms - fogs come on by themselves, some lights don't work....
Takes only a few minutes to replace.
Old 23 Feb 2010, 01:31 pm
Replace the switch nright away. Fires have been known to start because of the switch.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 23 Feb 2010, 08:37 pm
Yeah I read those, but none of the symptoms I found in them match what I'm experiencing, so I thought I'd ask.
Really? I hope that don't happen.
Old 10 Mar 2010, 04:35 pm
So it ended up being the fuse. The tabs holding the fuse were loose and caused a spot of high resistance in the connection, burning the contacts. Used a screwdriver to bend the tabs close together, put some dielectric grease on it, and put a new fuse in, and voila! It's working.
So now I have a good multi-function switch for sale if any of y'all want it.
I need this multi-function switch... anyone? Rowdy Classifieds: Want To Buy 12 07 Apr 2017 10:34 pm
how to install multi-function switch? Juicy General PT Cruiser Discussions 44 14 Apr 2014 01:13 pm
Multi-function control switch RNCRUZR General PT Cruiser Discussions 5 05 Jun 2009 06:22 am
WTB - Multi-Function Switch ucantcme Classifieds: Want To Buy 11 13 Oct 2008 03:03 pm
Multi function levers Liebman Tech & Performance Forum 2 15 Jan 2008 03:22 pm
