When to get a tune up and how much will it cost
Old 27 Feb 2010, 02:04 am
Default When to get a tune up and how much will it cost
I purchased a 2007 PT Cruiser base and it had 30299 miles on it. So far I have close to 36000 miles on the car and had the air filter changed and a very thorough oil change a month after buying the car. When is it a good time to get a tune up and how much would that cost? Thanks
Old 27 Feb 2010, 02:13 am
Default Re: When to get a tune up and how much will it cost
Welcome to the forums.
If you're handy you can do the plugs & wires yourself - I did.
Here's a guide:
2006-Up Pt Cruiser Spark Plug Removal.
Plugs are cheap, wire sets are $50 & up - do not buy stock wires - Autolite, MSD, etc are better.
Gap at 0.040.
At 30,000 miles - it's time.
Old 27 Feb 2010, 02:17 am
so all that is needed are new spark plugs??? I don't know how to change spark plugs. The only thing I changed on the car was the tail lights because the bulbs blew out.
Old 27 Feb 2010, 04:51 am
The traditional tune-up is pretty much a thing of the past...points and carb are long gone. At 36000, a fresh set of plugs would be nice. Other than that, check all the fluids, a good visual inspection for leaks, loose components, and belt condition. Check the tires for wear. Lube the grease fittings. Might want to look at the brakes as well.
Old 27 Feb 2010, 06:17 am
Go to this link, it will show you how to change out the plugs. You do not have a EGR valve so you can disregard the info about the EGR pipe removal.
BTW, Welcome to the Forum!
Old 27 Feb 2010, 09:10 am
Dino's Avatar
Wires and spark plugs and pcv valve. If you don't feel comfortable doing it and you have a trusted mechanic, than do some forum reading and order some quality parts and let your mechanic put them in. If you decide to do it yourself it's not very hard if you have a place to work, I just did mine the other day it wasn't hard but the weather made it non enjoyable.
I have a thread running on spark plugs, some good advice in it from some of the guys. I'm also very happy with the selection of parts I made.
Old 06 Mar 2010, 02:24 am
I am goingto auto zone later today to get the spark plugs. Now I have a 2007 base model PT. On the autozone website they have different types of spark plugs. Which one should I get? The Platinum plugs or the Iridium plugs. Also what is the difference between the two?
Old 07 Mar 2010, 09:54 am
Dino's Avatar
If you have a turbo don't get the Platinum from what I have read they don't hold up in the turbos, I bought the Denso Iridium, very happy and so far happy with the way the car runs. If you haven't done the wires yet you may want to the stock ones suck monkey butt
Tune-up ? discovering06 Tech & Performance Forum 6 11 May 2008 03:56 pm
New guy needs some tune up help MusiciansPT Tech & Performance Forum 5 02 Jul 2007 06:35 pm
The $6,600 tune up turbomangt The Detail Shop 2 09 Jan 2006 03:00 pm
Tune Up Alan Tech & Performance Forum 6 28 Aug 2004 04:27 am
TUNE-UP HELP? 1lowufo Tech & Performance Forum 2 15 Aug 2004 10:15 am
