STRIPPED SPARK PLUG HOLE
Old 27 Feb 2010, 12:42 pm
Default STRIPPED SPARK PLUG HOLE
Help,
My number 1 spark plug hole is stripped!
What to do?
Thanks,
Chuck
Old 27 Feb 2010, 01:22 pm
Matt42's Avatar
Default Re: STRIPPED SPARK PLUG HOLE
Bummer, but not the end of the world. Can be fixed, and easier on a PT Cruiser than on, say, a 1967 Mustang 390 with air conditioning.
I did a quick google search on "spark plug rethreading kit PT Cruiser" and got a bunch of hits. This is a sample 5-PIECE SPARK PLUG HOLE RE-THREADING KIT - CarParts Quality Discount Parts and Accessories
A decent parts store can help you out. I suggest that you fashion an extension wand for your shop vac to clean out the cylinder the best you can before startup, though.
While you are at it, buy a name-brand torque wrench that'll display 13 ft-lbs so it won't happen again. I suggest against the clicker kind. Clickers are OK, in my opinion, for torques over, say, 30 ft-lb where a 5 ft-lb error isn't so possibly devastating.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 28 Feb 2010, 11:25 am
Thank you much. Fortunately I already had one of the kits that you posted the link to. I was kind of hoping that someone would pop up and say "that's easy, just...". Unfortunately I had to tap the hole with the kit you described putting shavings in my freshly rebuilt motor. After using the compressor and shop vac, I cleaned out the hole to where I could find no more traces of shavings and the spark plug is in!
Thanks again,
Chuck
Old 01 Mar 2010, 02:29 pm
twress's Avatar
Thanks again,
Chuck
A magnet works good to get out the small shavings in the hole that might have fallen inside.
ROUNDIN UP THE WAGONS 02 LIMITED WOODY, 89 CAPRICE CLASSIC
Old 01 Mar 2010, 09:31 pm
Unfortunatly the head is made out of aluminum and so the shavings that fall will be aluminum and magnets don't stick to them.
Old 01 Mar 2010, 09:52 pm
twress's Avatar
Sorry I was thinking of the last vehicle that I had to do that to. forgot.
Oil coming out of spark plug hole 2004PTCruiser Tech & Performance Forum 10 31 Jan 2012 11:28 am
Spark plug threads stripped in head. What are my options? WalterZoomie Tech & Performance Forum 6 12 Nov 2009 03:45 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
Spark Plug GAP duffner General Turbo Discussions 11 16 Mar 2008 12:55 pm
Spark Plug Gap sakigt Turbo Performance 8 09 May 2003 03:47 pm
