Ground wire placement?
Old 28 Feb 2010, 11:20 am
Default Ground wire placement?
2002 touring edition 2.4 w/AC
Please tell me where the ground wire hooks up on the passenger side. It is connected on the bracket that holds the upper motor torque strut and from there I don't know. There is also a small hole in the valve cover just beside where the PCV valve enters the valve cover. Is this left open?
Thanks,
Chuck
Old 28 Feb 2010, 10:27 pm
Default Re: Ground wire placement?
Found it! Ground wire went to the back of the head close to the center.
The hole I was asking about is not blowing out or sucking in at start up so I will let it be.
Thanks anyway,
Chuck
Old 01 Mar 2010, 07:24 am
Chuck,
That hole (if I'm thinking of the right one) is for a vacuum line that runs to the air intake. You can just see the line in the picture below.
Ground wire elmeyer Tech & Performance Forum 2 01 Nov 2009 08:40 pm
Ground wire on hood? Hoot23 General PT Cruiser Discussions 1 15 Jul 2007 11:23 pm
Crappy Ground Wire Mean Green General Turbo Discussions 2 31 Dec 2004 09:56 pm
Added ground wire=better performance? littleblueGT Turbo Performance 17 06 Nov 2004 10:02 pm
Ground wire on hood?? wyzard Tech & Performance Forum 2 16 Apr 2004 11:05 pm
