06PT radiator fan randomly stays on and drains battery
Old 02 Mar 2010, 04:27 pm
Question 06PT radiator fan randomly stays on and drains battery
I have replaced the battery and the fuse for the fan (50 red I believe) and I am a bit stumped at what it could be. The fan activates when it should however it occasionally wont shut down and kills the battery, so I pull the fuse when I park it. Anyone have a similar issue or heard of a malfunction like this? NO check engine light.
Old 02 Mar 2010, 05:06 pm
Default Re: 06PT radiator fan randomly stays on and drains battery
Welcome to the Fourms.
I don't know where it is, but there's a temp sensor that tells fan to turn on - I suspect that's bad - also, the fan is to come on when A/C is on, that could also be your problem -
I also think the fan should go off when the key is off, it might be ignition switch.
Some ideas....
Old 03 Mar 2010, 12:32 am
I won't pretend to know how the cooling system is engineered in detail but I would look at my cooling fan relays. If you blew a fuse (50 amp) and a big one maybe there's something going on inside the relays. I am thinking a skewed set of points on the relay contacts making them stick close even when the relay is off. I too think the fan should turn off with the ignition. I think the power feed to the fan motor is hot all the time and thus could cause this to happen.
Tags
battery drainage, electrical, fan
The radiator fan fix 03PTMOM Tech & Performance Forum 26 25 Sep 2014 01:02 pm
03 ptc randomly dies, electrical? snix Tech & Performance Forum 2 31 Oct 2009 11:25 pm
Engine Light Stays On - OBD vinzchlortho Tech & Performance Forum 6 30 Nov 2008 07:01 pm
Theft alarm light stays on 24/7 slong General PT Cruiser Discussions 0 16 Jun 2008 09:45 pm
Alarm randomly goes off memejane Sound and Security Forum 5 03 Dec 2007 02:16 pm
