Battery Cable Confusion
Old 03 Mar 2010, 01:48 am
Default Battery Cable Confusion
did an engine swap on an 01 pt cruiser for a friend and had some bad battery cables. got new mopar cables from my local dealership and installed them, car would not crank or start. attached the tab to the starter, now it cranks but still wont start. i have a lone free connector from the positive cable and no idea where it goes. i've tried seeing where its supposed to go but am stumped. i'm positive its preventing the car from starting but i just need help. attached is a picture of the connector. please advise, thanks in advance!
Old 03 Mar 2010, 01:50 am
Default Re: Battery Cable Confusion
That is chasis ground. Goes on left side of battery with another cable running towards firewal.
Silver 2007 5 speed with Airaid intake, custom exhaust, E3 plugs, 17" 1000 maglia 5 spokes and Sumitumos, Yakima basket case, and hitch receiver.
Old 03 Mar 2010, 02:04 am
safe to assume the car won't start with it ungrounded then? i'll see what i can do to ground it out.
Old 03 Mar 2010, 07:45 pm
Be sure you never ground a positive cable, there are two positives.
The starter solenoid leg and the control box leg right behind the air box.
Old 04 Mar 2010, 01:35 am
ok it starts and runs, but i have this issue;
the engine idles poorly and the throttle races if you even breathe on the pedal.
Old 05 Mar 2010, 07:34 pm
Given that short video, I would say a vacuum leak. Could be lines not connected at the back of the intake facing the fire wall, check both ends. There are others as well. I would look at the intake gaskets as well. With an exhaust noise hearing a vacuum leak would be unlikely so you have to feel around for something missing... Nice to see ya install an engine, good job ! The little things left will get resolved in time. Good luck
Old 05 Mar 2010, 10:55 pm
thanks for the compliments. this car has been a little tougher than i thought. i specialize in mazdas and this is the first chrysler swap i've been involved in since my brother's 96 neon engine popped.
there was a broken stud between the two manifold plenums on the intake side, so i'm going to replace that and see if that smoothes out the problems.
Battery Cable Assembly... Whats the Deal PTGirl2001 General PT Cruiser Discussions 13 10 Jan 2014 09:57 pm
Battery Cable Assembly... PTGirl2001 Tech & Performance Forum 0 19 Nov 2009 01:00 am
Fuse confusion...... Stone-PT General PT Cruiser Discussions 7 26 Feb 2005 07:42 pm
Disconnecting battery cable TaylorMade Tech & Performance Forum 6 08 Aug 2004 11:24 am
Nut size for the negative battery ternimal cable. KingKole02 General PT Cruiser Discussions 14 23 Apr 2004 12:41 pm
