Power Steering Fluid
Old 05 Mar 2010, 01:23 pm
Default Power Steering Fluid
What power steering fluid do you add to in a 2001 PT? Can you use ATF-4 with the factory fill or do I need to find some of what they used for the 2001s?
Old 05 Mar 2010, 02:16 pm
Default Re: Power Steering Fluid
The factory fluid is ATF+4.
Old 05 Mar 2010, 04:55 pm
There was a TSB out
Here is a copy TSB 18-029-01
The 2001 PTs used MS9933, and the 2002+ use MS9602 which is ATF-4.
This TSB TSB 19-005-03
suggests that you should not mix them.
MS9602 should not be mixed or used as a “topping off” fluid on systems requiring MS5931. On some past models, MS9602 should be used as the replacement fluid. On these models, if a power steering system is being serviced that results in a large fluid loss, such as a pump, hose or gear/rack replacement, the complete system should be drained and filled with MS9602.
So it looks like I get to drive ~30 miles to find a Chrysler dealer, since they closed all of the local ones.
Old 05 Mar 2010, 07:49 pm
Dino's Avatar
Originally Posted by ptal View Post
There was a TSB out
These PT's have some complicated fluid issues, I used to be able to buy what ever name brand was on sale and was good to go with my old Toyota.
Old 05 Mar 2010, 09:40 pm
I use this.....
https://www.amsoil.com/catalog.aspx?code=PSFCN-EA
2001 Limited Edition
power steering? PTcruzer02 Tech & Performance Forum 7 25 Feb 2012 11:39 am
Power Steering Fluid jmack General PT Cruiser Discussions 12 25 Dec 2008 11:55 am
Gasoline and Power Steering Fluid DIYPTGUY General PT Cruiser Discussions 11 29 Nov 2008 01:47 am
TSB on Power Steering fluid? PTGT Redman Tech & Performance Forum 10 31 Mar 2004 06:42 pm
power steering cap sugoi General PT Cruiser Discussions 6 25 Feb 2004 09:24 am
