Custom Wheels
Throttle cable adjustment
Old 07 Mar 2010, 12:19 pm
Default Throttle cable adjustment
It seems things on this friggin car break for no reason what so ever.
Now the throttle cable is slacked about an inch and a half, and I need to know how to readjust it.
Do you do it from the throttle body, or where it connects to the pedal? and how so, I dont have hardly any cable to tug on down by the pedal.
most cars have adjustment nuts on the throttle body, but I didnt see anything.
Old 07 Mar 2010, 02:32 pm
Default Re: Throttle cable adjustment
We're talking about the two cables that run across the upper manifold right? One for the cruise control, one for the throttle. I did a fast search but can't find anything on adjusting it but isn't there some sort of adjustment nut on the cable itself where the bracket it that holds the cables in place?
P.S. Forget about the yellow asterisk on the picture. That shows the placement of the IAC.
2000 PT. Original Owner, 115,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
NY Times article: http://www.nytimes.com/2008/10/30/au...30vintage.html
Old 07 Mar 2010, 10:38 pm
Well,
What is going on with the cable ? What set of circumstances leads you to make this statement ? You've made a determination being on-site, we are way out here in left field.
Old 10 Mar 2010, 12:18 pm
Originally Posted by driveability View Post
Well,
The throttle cable is loose, allowing the gas pedal to flop all over the place, and I can tug on the cable and pull about an inch until it sinches up snug.
Is there something where it attaches to the pedal that you can loosen up to adjust the cable?
Old 22 Apr 2011, 11:52 pm
Question Re: Throttle cable adjustment
Hi all,
How to adjust the throttle control cable on 2004 Chrysler PT cruiser?
Thank you for your help.
Old 23 Apr 2011, 02:21 am
i added a throttle body spacer and this took up the slack as i could not see how to adjust it, that was 2 years ago and its still ok
Old 23 Apr 2011, 01:27 pm
But what caused a cable to suddenly develop one inch of slack? typically, the cables are cut to length with threaded end caps for some adjustment but an inch on that cable sure seems like a lot.
Any possibility the cable came off it's track/roller along it's path?
alan
Loose Throttle Cable? ucantcme General PT Cruiser Discussions 1 18 Sep 2008 07:03 pm
headlight adjustment??? coco1476 Tech & Performance Forum 4 13 Sep 2008 05:39 pm
Top Adjustment leftyvert PT Cruiser Convertible Forum 9 22 Dec 2007 08:39 pm
rear toe adjustment rte662006 General PT Cruiser Discussions 8 26 Dec 2005 02:25 pm
Sloppy Throttle cable 1lowufo Tech & Performance Forum 1 09 May 2004 12:45 am
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
