Adjusting Gas Pedal Sensitivity
Old 08 Mar 2010, 08:41 pm
Default Adjusting Gas Pedal Sensitivity
I have an '01 automatic that I purchased last year. I've noticed that (when the engine is off) the gas pedal seems a little loose. When the engine is on, you have to push quite a bit to get the RPMs up.
How (if even possible) can I adjust the pedal (tighten/loosen) or adjust related cables or linkage (is this car a drive by wire?)? I checked the throttle body and the wire that leads through the firewall doesn't look adjustable.
Thanks for your response, everyone!
Old 08 Mar 2010, 09:12 pm
Default Re: Adjusting Gas Pedal Sensitivity
If you have cruise control there's a double cable/wire that runs over the upper intake and onto metal spring loaded wheels. One cable is for the cruise control, the other is the throttle body. You can check to see if there's some sort of adjustment on those cables. They should be tight around the wheels. Any slack and that will be your loose feeling at the gas pedal.
The yellow asterisk is pointing to the IAC (Idle Air Controller).
Old 08 Mar 2010, 09:24 pm
Crewzin,
Thanks for your response. I know you've responded to some of my other questions, you are very knowledgeable! I have updated your picture so I can reference what I am talking about below. My description skills aren't the best.
If you'll check number one, both throttle cables are pretty loose. The loosest, though, and clearly so (isn't even on the spring, I guess it "connects" on use), is the one that points to number one, which I assume is the cruise control.
I can't find a way to tighten either of these...I'm hoping I'm just missing something.
Thanks again.
Old 08 Mar 2010, 09:34 pm
#1 box. As I said, one of those wires goes directly to the cruise control in the far left corner (#2), the other comes around and goes to the firewall and up to the gas pedal (I think). They are both attached to that spring loaded wheel and there's hardly any slack on either wire. I'm not sure how to adjust the slack out of it but that's probably your problem, too much slack.
Old 08 Mar 2010, 09:35 pm
Ok, that's what I was thinking. The service manual (from what I can find) doesn't mention tightening it, and I can't find it on the Internet anywhere.
Thanks.
Old 10 Mar 2010, 01:20 pm
Thanks.
I have the same thing going on, I need to tighten up my slack on my throttle cable. but I have no idea how to on the cruiser.
if you find the answer, please post it on here so I can fix this on my car also.
Old 10 Mar 2010, 04:44 pm
Please do the same for me if you find out how.
Old 10 Mar 2010, 06:54 pm
Dino's Avatar
My 04 is a little odd also, it has a firmer pedal than I'm used to I find it's very hard to take off easy from a light. I'm getting used to it though.
Old 13 Mar 2010, 04:22 pm
Did anyone ever figure out a solution for this?
Old 13 Mar 2010, 08:13 pm
I agree... its taken a bit to get used to.
Charliehorse
2010 Classic in Deepwater Blue w/Grey Interior
2008 Bullitt Mustang #901
Adjusting Wiper Fluid Jets?? William_F General PT Cruiser Discussions 6 10 Jan 2010 07:39 am
Fog Light Adjusting Question Graveone General PT Cruiser Discussions 3 24 Jan 2005 12:09 pm
MOMO Pedal Set + Dead Pedal (Manual) **SOLD** Beacon Classifieds: For Sale/Trade 0 06 Jul 2004 07:28 pm
PCM adjusting for ram-air hood? Mihoshi Turbo Performance 0 28 Jun 2004 03:21 am
replacement gas pedal and brake pedal?? legion Interior Accessories Forum 7 17 Jun 2004 10:06 am
