PCM intermitent malfunction
Old 15 Mar 2010, 02:26 pm
Cool PCM intermitent malfunction
Hi there...I've got a 2003 GT Cruiser 2.4L Turbo and I was getting a faulty code P0344 and I've found that it was related to my Camshaft Position sensor...So I changed it...and even after changing the part, I was Still getting the code. I've tought that it could be related to a faulty groung or bad voltage going to the sensor...wich I was getting the required 5V on high and the 0.30 V on low....Then I tought of tapping on the PCM module with the handle of my screwdriver and I noticed that when I was tapping on the second terminal of my PCM the engine would start to rough idle and or would die...what can I do to fix this issue...is it common? Do I have to change the PCM? I need help please !
Old 15 Mar 2010, 08:23 pm
Default Re: PCM intermitent malfunction
Just a guess but it sounds like yo have a bad connection/solder joint/wire in the computer. Maybe somehow you can pin it down to something that can be fixed but normally PCM's are replaced not fixed.
When you replaced the camshaft position sensor did you take the negative battery cable off when you fixed it. Hopefully you did. That would stop any stray spark and get rid of any old fault codes so you aren't reading the same fault.
No, a bad PCM is not common.
Old 15 Mar 2010, 09:54 pm
Cool Re: PCM intermitent malfunction
I did take the negative off...but I'm wondering how to test and pin point if it's the PCM or The connector itself....PCM can be costy...hopefully I can fix it !
Old 16 Mar 2010, 11:32 am
Also - the Cam sensor - was it a dealer part? Many have had problems with aftermarket sensors....
Also, I've read of people getting PCM replaced under a federal emission warranty???
Tags
"pcm" "p0344" "p0339"
Intermitent rough idle argos587 Tech & Performance Forum 9 23 Mar 2009 07:29 pm
intermitent electrical fault harrisonmml General PT Cruiser Discussions 9 24 Jan 2008 12:28 pm
AC malfunction tezz Stage Turbo Kits 4 27 Apr 2004 02:45 pm
ABS Malfunction? spicy pt General Turbo Discussions 6 26 Apr 2004 05:01 pm
malfunction in fog lights bigdaddy2o General PT Cruiser Discussions 9 09 Apr 2004 03:20 am
