Airbag Seat Sensor???
Old 16 Mar 2010, 01:48 pm
Default Airbag Seat Sensor???
Got that darn airbag light on again, and we took it to a shop where we know the owner, and they are telling me that the seat sensor is dead and causing the issue.
It makes sense that there was something wrong in the seat as there was a point where if you bounced in the seat hard enough the light would come off and on.
However I cant find a "seat sensor" on the internet.
Has anyone heard about this seat sensor? I just wanted to see what prices on it would be, as the mechanic is still looking a replacement part.
Thanks all....
Old 16 Mar 2010, 02:17 pm
Default Re: Airbag Seat Sensor???
I think what your looking for is the Occupant restraint Controller. I can't find anything in a search about a seat sensor. Now it's possible i missed it. But there sure is a lot on the controller and it might be a Chrysler only part.
The front airbag system electrical circuits are continuously monitored by a microprocessor and software contained within the Occupant Restraint Controller (ORC). The ORC also contains impact sensing elements, which are monitored by the ORC to determine when an impact occurs that is severe enough to require front airbag system protection. The Occupant Restraint Controller (ORC) is mounted on the tunnel floor pan, between the transmission shifter and parking brake, under the floor console. The impact sensing device is an accelerometer that senses deceleration, which provides verification of the severity of an impact.
Old 17 Mar 2010, 11:39 pm
Was this on the driver's side or passenger's side? The "seat sensor" is called an occupancy sensor, and is located in the seat cushion. It detects when enough weight is placed on the seat to activate the airbag. They're replaced by pulling off the seat cover, and it's located right on top of the seat cushion.
They can be broken by placing abnormally shaped objects in the seat, such as kneeling on the seat, or any kind of blunt heavy object.
-Chris
Old 18 Mar 2010, 02:51 am
Thanks for correcting that Chris.
Old 21 Apr 2010, 11:43 am
So I thought we had this licked, as we have a friend who runs a shop and said he found this to be the problem, and ordered the replacement part.
However he has since fallen off the face of the earth.
I cant find anything on the internet about this occupancy sensor, and the dealer is being a jerk and still trying to tell me the whole air bag needs to be replaced.
Anyone know how to find this part, and what it would be "officially" called?
Another question is I am also having slight difficulties with the horn on the car. Sometimes when you press the horn it does nothing, and then if I hit it hard enough it will work for a while.
I have read somewhere that this could be contributed to a clock spring issue which also controls the airbag light? Any way to know and how difficult it is to replace.
Old 01 May 2010, 06:18 am
Hi,Im having simlar problems with the air bag light that seems to have a mind of its own and comes on at random times.
It happens more to me then my wife (im slightly larger then she is by about 8 stone!) so this seat sensor thing sounds like a good place to start.
Read on other places about problems with broken wirering inside the seat but havent made a start on finding fault yet..
Old 02 May 2010, 12:50 am
I already told you it's called an "occupancy sensor". That's the "official" name for it.
I'd probably get another opinion. Your indy will not have the level of diagnostic equipment that the dealer has, and if they says it's the airbag itself, it's worth a trip to the next closest dealer for another opinion.
Another possibility is the pretensioner.
-Chris
Old 19 Jul 2010, 06:48 am
I was told that you could put a resister in line with the airbag light and this would make it go out on drive.
has anyone heard of this
Old 19 Jul 2010, 03:01 pm
I wouldn't recommend it. Disabling or tampering with the airbag light is illegal.
-Chris
Airbag light ON sullyfla Tech & Performance Forum 10 18 Feb 2017 10:59 am
Drivers seat head/leg room; power seat vs. manual seat pstar General PT Cruiser Discussions 10 01 Jun 2016 01:15 am
Problem with Passenger Seat Airbag Sensor Orangestng General PT Cruiser Discussions 1 06 Aug 2009 04:35 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
Airbag lite on need help dafaic General PT Cruiser Discussions 2 03 Oct 2007 06:27 pm
