car would not start, now keyless entry does not work.
Old 17 Mar 2010, 01:33 am
Default car would not start, now keyless entry does not work.
the problem started when I went to open my 2001 pt cruiser. I had to open the car with the key because the fob was not working which set off the alarm. I then proceeded to start the car, but it would not start, just the clicking of the starter. I jump started the car and got it home only to find out both my fobs do not work. So I have two problems. First the car would not start apparently from a dead battery. The battery is only 1 yr old and there was nothing left "on" in the car. It's not the alternator and the battery is good. What could have caused the starting problem? Second, both of my Fobs mysteriously stopped working on the same day. I can only get into my car with the key. I tried to re-program the fobs by following the instructions in the manual (inserting key, turing on, holding unlock, etc...) but that was unsucessfull any suggestions before I take it to the dealer?
Old 17 Mar 2010, 07:23 am
Dino's Avatar
Default Re: car would not start, now keyless entry does not work.
Did you test the battery? It might be bad, because you were able to jump the car. I would bring it to a place like Pet Boys that would test it for free before you give the dealer a chance to hose you.
Old 17 Mar 2010, 10:12 am
Welcome to the forums.
Agree - get battery & charging system checked before you go nuts. When battery on a PT goes, weird things arise.
As to what drained your battery, the multi-function switch often goes bad and turns lights on by itself.
Old 18 Mar 2010, 11:50 pm
I took the car to the dealer and had them test the fobs and they were both transmitting a signal. So the dealer re-programmed them to the car and everything seemed fine, but two days later both fobs stopped working again. I think it may be the remote keyless entry module. That is also my guess as to why the car wouldn't start. I think the car may have locked out keeping it from starting. Anyway, I've been trying to find a part number and a place to buy the rke module. Anyone have any suggestions? Oh, and the battery tests out fine.
Tags
fob, key remote lock, starting
keyless entry chintzgirl General PT Cruiser Discussions 3 29 May 2009 07:12 pm
keyless entry dpmeeks General PT Cruiser Discussions 6 13 May 2009 05:52 pm
KEYLESS ENTRY? DevilMan General PT Cruiser Discussions 1 01 Apr 2006 08:48 pm
Keyless Entry Opiate Sound and Security Forum 3 16 Jul 2004 03:28 am
Keyless entry? Blade General PT Cruiser Discussions 13 22 Mar 2004 05:52 pm
