Modified Airbox Question
Old 22 Apr 2002, 04:13 pm
Default Modified Airbox Question
Hi All, I've been messing around with my airbox, and at present have a 3" pvc intake hole where the stock snorkle was. It's working and sounding so much better than the stock set-up, I'm wondering if I'm missing something (i.e. really cold weather performance). I'm also wondering, given the set size hole going out of the airbox lid (with the white piece off), what would the max. effective intake hole size be? Would a 4" hole be overkill or almost there? Any thoughts or ideas?
Keep on Chruzin !
Old 22 Apr 2002, 08:37 pm
Since the throttle body throat is a limiting factor, if you go too large on the intake it may actually be detrimental since you could lose the inertia effect if the flow velocity is too low.
Old 23 Apr 2002, 01:31 am
Hi CTF, yeah, that's kind of what I was thinking. But what about the open cone filters? Since they're totally open, wouldn't that sort of be comparable to having the stock lid with a K&N drop-in hooked underneath, but with no airbox bottom at all? I know you wouldn't want to really do that because of sucking in all that engine heat right there, but wouldn't the air movement be similar by the time it gets to the throttle body?
Keep on Chruzin !
Old 23 Apr 2002, 05:20 pm
Actually, I was thinking in terms of the pipe going from the filter box to the throttle body, since the stock tubing is about 3" in diameter. A smooth wall pipe with a cone filter works real well for increased airflow but I don't know how large a diameter you can go before it works against you.
2003 PT Turbo - Heavily Modified - Check it out..! GT2nr Classifieds: For Sale/Trade 5 02 Dec 2005 12:46 am
AIRBOX INLET QUESTION clevelandmike Tech & Performance Forum 6 20 Oct 2004 04:34 pm
Cleaning oil in the airbox crazie.eddie Tech & Performance Forum 4 11 Sep 2004 04:32 pm
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
"Your airbox has a piece missing!" skylight General Turbo Discussions 16 11 Jul 2003 11:38 am
