Water Pump (Mega FAIL)
Old 21 Mar 2010, 07:37 pm
DigitaL101's Avatar
Default Water Pump (Mega FAIL)
Water Pump started leaking after a boiling overheat , expected bad bearing or bad seal ..... never expected this .
What the hey .... could this possibly be normal where and tear ?
What happend here , and were did the rest of it go ...
The blades on this thing feel as though there made of tin .
Is there a "prefered" pump maker ? a pump with a little more "meat on the bone" ??
2002 Limited 5 Speed
Old 21 Mar 2010, 09:57 pm
Default Re: Water Pump (Mega FAIL)
I would seriously check the rest of the engine if you can't find the missing pieces. The last thing you want is to have one of the blades blocking a water channel destroying your engine (by overheating).
-Chris
Old 21 Mar 2010, 11:08 pm
767skyking's Avatar
I would remove the radiator hoses, heater core hoses and reverse flush both and the engine.
Old 22 Mar 2010, 12:05 am
DigitaL101's Avatar
Roger that guys ..
That right now is my greatest concern , thats a pretty large piece of metal floating around in there ... or most likely , lodged in a narrow water jacket somewhere .
on second look , its actualy three missing blades ....
i did a primary flush before the pull down , plenty of "green" non HOAT fluid
no foreign material , i'll do a more vigorous flush and see what i can find . I'll put on an old hat , find me some screen and pretend its 1849 .
on a brighter note , i think i found my overheating problem ..
Water Pump rute66pt General PT Cruiser Discussions 4 03 Dec 2009 01:56 pm
How many bolts in the water pump? 2001PTCRUZ Tech & Performance Forum 1 07 Aug 2009 07:26 pm
water pump replacement questions JakeBrakeIH Tech & Performance Forum 10 25 Nov 2008 07:43 pm
water neck for the water pump Boxerjl2 Classifieds: For Sale/Trade 3 31 Jan 2008 02:48 am
Bad water pump/head gasket Gloria J Tech & Performance Forum 4 28 Oct 2003 06:06 pm
