2002 PT Cruiser Engine Swap
Old 28 Mar 2010, 06:28 pm
TurboDucky's Avatar
Question 2002 PT Cruiser Engine Swap
Hi all. I'm trying to purchase an '02 Cruiser with a supposedly bad engine. (From a Salvage Yard) They're telling me that the engine is a "2.4 PT Cruiser only" engine. I'm having a hard time believing that Chrysler designed an engine specifically for the PT Cruiser. I'm guessing it's the same block as the Stratus / Sebring? (I'm actually hoping it only needs a timing belt...)
Can anyone shed some light on the interchangability?
Thanks in advance.
Old 28 Mar 2010, 07:48 pm
Default Re: 2002 PT Cruiser Engine Swap
You're sorta right - blocks are the same, tho they have changed over time - but the SRT-4 Neon, for example, while it has the same block, has a different intake, and different exhaust.
It's tight in those engine bays.
Old 28 Mar 2010, 07:57 pm
TurboDucky's Avatar
I just read through the 2.4 Engine builder document. It appears that the biggest difference would be the oil pan. They had to relocate the filter to make it fit in the PT Cruiser. I'm guessing any 2002 2.4 would be the same block. Just need to use the PT Oil Pan / Intake / Exhaust / Etc.
Old 28 Mar 2010, 10:23 pm
cruserdad1976's Avatar
there is something about where a sensor is or how it is read that is a BIG issue
Old 29 Mar 2010, 03:57 pm
TurboDucky's Avatar
Yeah, I read that. I still think as long as I stay with a 2002 block I'll be ok. I guess I'll find out soon. I was able to buy it. It's a 2002 Limited, 120k miles, 5 speed. Someone has put aftermarket wheels, and a Hurst shifter in it. Bought it for $1300.00 - I'll let y'all know what I find.
Old 29 Mar 2010, 09:40 pm
Dino's Avatar
Why don't you pull the PT engine apart and see what the problem is? Maybe it can be saved and rebuilt.
Old 03 May 2010, 08:56 pm
TurboDucky's Avatar
Well, I removed the oil pan and checked it out. It apears to have ripped the bottom out of the #4 piston. I bought a 46k motor out of a 2001 Sebring, and just got the engine pried out of my Cruiser. Now, I need to make the Sebring engine look like a PT Cruiser engine. It appears that the only thing that matches is the block assembly itself..... I have to swap all of the brackets, EGR, Oil Pump, Oil Pan, Intake, Exhaust, Etc, Etc....
This ought to be a hoot!!
Old 11 Jun 2011, 11:45 am
Send a message via Yahoo to pieface85
Question Re: 2002 PT Cruiser Engine Swap
I'm curious about how the 2002 pt turned out and if I can make it a little easier by using a 2002 neon engine
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
2002 PT Cruiser engine problems bastropcruiser Tech & Performance Forum 2 11 Feb 2009 08:54 pm
2002 Dream Cruiser trany swap?!?! dougrose Tech & Performance Forum 2 07 Feb 2009 05:41 pm
sudden engine fire in 2002 pt cruiser dagna General PT Cruiser Discussions 23 07 Jun 2004 10:53 pm
Engine Swap macster Turbo Performance 3 24 Feb 2004 12:01 am
