Camshaft/Crankshaft Synchronization Procedure
Old 29 Mar 2010, 08:57 pm
DigitaL101's Avatar
Default Camshaft/Crankshaft Synchronization Procedure
Anyone familiar with this ?
Was looking over an AutoZone manual about head bolt torque sequence , and ran across this ...
"After all components are installed on the engine, a DRBŪ scan tool is necessary to perform the camshaft and crankshaft timing relearn procedure."
The last three steps say ..
7.Fill the cooling system.
8.Turn the ignition switch ON , and access the -miscellaneous- screen.
9.Select the -re-learn cam/crank- option, then follow the instructions on the scan tool screen
My list ended at 7 ...
This is a new one on me guys , Could someone go into more detail , that scan tool sounds kinda pricy , is there another way to initiate this proccess .
Is it realy neccessary , cant remember seeing one word about it in all of my prior research ...
2002 Limited 5 Speed
Old 12 Apr 2010, 01:21 am
Default Re: Camshaft/Crankshaft Synchronization Procedure
I would also like to know about this procedure. Is it necessary to hook it up to a DRB scan tool after replacing headgasket and timing belt without
disconnecting the negative on the battery? I've looked online and its a dealer item only.... or you can buy one for $7-8k!
MX-5 'Burp -Free' Mod. Procedure IRPT Tech & Performance Forum 96 29 Jul 2015 07:46 am
Automatic Transmission Learning Procedure?!?! GLH_TC 16V General Turbo Discussions 11 11 Jul 2013 09:34 pm
Plug change procedure question sawdust123 General Turbo Discussions 14 07 Dec 2007 04:04 pm
Procedure for changing wires and plugs? snakepitt1 Tech & Performance Forum 8 07 May 2004 09:18 am
crankshaft pulley removel fugittj Tech & Performance Forum 0 01 Jan 1970 12:00 am
