PT Cruiser Forum Car Videos
Custom Wheels
Oil Filter Location
Old 22 Oct 2003, 01:59 pm
PT-ERA PT-ERA is offline
Default Oil Filter Location
Okay, I've had my PT for about 2 months and I'm only 1K away from my first oil change. Can anyone tell me where to look to find the oil filter on the car? I looked but could not see it. Is it in an out of the way spot? Help!
Also, when is a good time to switch to a synthetic oil? She only has 20K on her. Should I do it now, later, what's a good brand to use? Thanks in advance for all your help!
[8)]
Old 22 Oct 2003, 03:00 pm
rice_killing_GT rice_killing_GT is offline
If you were looking from the engine bay for the filter you probably won't see it if you don't know exactly where it is. But the filter is easily accessible from the bottom no problems finding it once your under the car.
I switched to Mobil1 on my first oil change at 3,000 as alot of owners here so it shouldn't be a problem.
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 23 Oct 2003, 06:57 am
Mark1 Mark1 is offline
Send a message via AIM to Mark1
The filter is just inside the Passenger wheel. If you do your own oil changes, you will find it a great location. I have even done a change with the PT on the ground with no ramps.
As far as changing over to synthetic. Some change right away but most engine builders say to give it about 3000 to 5000 before the change. So you are good to go. I think Mobile 1 is the most commonly used synthetic.
Old 23 Oct 2003, 12:49 pm
nhrapt nhrapt is offline
I use castrol syntec 5w30 and k&n oil filters on all our auto's and waited till i had 3,000 miles.But its your call, your car![8)]
flames&stripes by \"gator\" 2003 milan dragway \"chrysler classic\" winner
Old 23 Oct 2003, 01:56 pm
Cal Cruzer Cal Cruzer is offline
Be ready to use a wrench or something to get the factory installed filter off. They really bury it on there hard.
vB code is On
Cabin air filter AlmondTurbo General PT Cruiser Discussions 14 04 Apr 2008 06:46 pm
Whats up with factory oil filter yotehunter General PT Cruiser Discussions 10 09 May 2005 08:28 am
K&N filter oil on BTG filter? Punch Turbo Performance 1 15 Oct 2003 11:55 pm
replacing oil filter only boosta General Turbo Discussions 20 04 Aug 2003 10:14 pm
Oil Filter Removal jramosGT Turbo Performance 12 03 May 2003 06:44 pm
  Mortgage Calculator | Buy PSP | Loans | Remortgages | Buy Anything On eBay
