code P0401
Old 12 Apr 2010, 05:57 pm
Default code P0401
Hi! My check engine light came on today checked codes it was P0401 how easy is that to fix? do i need to take it to the repair shop or can fix at home? thanks everyone!
Old 12 Apr 2010, 06:08 pm
Default Re: code P0401
Code P0401 EGR flow insufficient
Old 12 Apr 2010, 06:42 pm
From PT Do-It-Yourself.net:
P0401 (M) EGR System Failure - Required change in air/fuel ration not detected during diagnostic test.
The P0401 is a very common code for the EGR. More than a few have been replaced under warranty on the PT. A new valve should cure the codes. Make sure you follow the replacement instructions precisely. Once it's replaced, the code won't clear itself using the battery disconnect technique. Have the dealer clear it using their DRB scan tool during your next visit.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Malfunction Indicator with P0401 code Patrick_Dickey Tech & Performance Forum 16 01 Jul 2011 08:52 pm
code 352 coco1476 Tech & Performance Forum 5 18 Jan 2010 05:19 pm
344 code jkinard73 Southeast PT Forum 2 08 Apr 2009 01:54 pm
what is this code medtwo Tech & Performance Forum 2 04 Dec 2008 07:54 am
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 08:03 pm
