03 cruiser running hot
Old 13 Apr 2010, 01:47 pm
cllwyrc's Avatar
Default 03 cruiser running hot
I recently bought a 03 cruiser and it tends to run at about 3/4 of the way up the gauge and the fan kicks on at the half way mark and doesn't shut off. Is this a thermostat problem or waterpump or something more sevier?
Old 13 Apr 2010, 03:14 pm
Dino's Avatar
Default Re: 03 cruiser running hot
Is it only at idle? Does it do it when your at say parkway speed? Any leakage under the PT? When the fan comes on does it go back down to half? Do you have the right coolant on the radiator? Has it ever been flushed? How many miles on the PT?
Old 14 Apr 2010, 02:06 am
cllwyrc's Avatar
PT has 94,000 miles. It has the green coolant in it & not sure how long it has been in there, there is no leaks & it will jump up 3/4 of the way up no matter if your moving or sitting still.
Old 14 Apr 2010, 08:20 am
cllwyrc,
Chrysler recommends HOAT coolant. It's red in color. It's possible you radiator is partially clogged because of the damage done by the wrong coolant.
Does the fan kick on before the half way mark if you have the A/C on? It should. If not you may have the lower speed part of the fan burnt out.
Other reasons for overheating, like you mentioned is the thermostat not operating properly or a damaged water pump that's not creating the proper flow.
First thing I'd do is check the fan operation, then have the coolant system completely flushed. Any signs of debris or rust in the radiator or it doesn't have a good flow then you'll know somethings wrong.
A work of caution: Your at the point (94K) that you'll be needing a timing belt and water pump change around the 100K mile mark. It's an expensive job requiring 5 to 7 hours labor from a competent mechanic. With parts and labor running anywhere from $800 - $1200 depending on the parts used and the hourly rate of the mechanic.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 14 Apr 2010, 10:43 am
cllwyrc's Avatar
it doesn't kick on until the half way mark unless you kick the a/c on.
Old 14 Apr 2010, 02:21 pm
Sounds like the fan is working correctly, at least on the low speed. Without the A/C there's no reason for the fan to come on until a preset temperature is reached. When it's get over that temperature, the high speed should kick on and bring everything back to half way.
You should be able to hear the difference of the high and low because the low makes almost no noise at all above the engine running and the high will be loud enough to hear by itself way above the engine noise.
Old 15 Apr 2010, 01:04 am
cllwyrc's Avatar
I forgot to mention that I don't have these problems at night when temps outside is cool except for the fan running on high once hitting the half way mark.
03 GT Cruiser wont stay running. 03GTCruiser Tech & Performance Forum 2 23 Feb 2010 12:14 am
cruiser will not stop running DreamPT416 Tech & Performance Forum 8 05 Dec 2009 07:39 pm
PT cruiser Overheating - fan isn't running Torashi Tech & Performance Forum 4 13 Jul 2009 02:37 am
2003 PT Cruiser running power oscar514 Tech & Performance Forum 1 28 Feb 2009 05:13 pm
up and running again careyk Canada PT Forum 1 19 Feb 2008 01:31 am
