cooling system ?
Old 20 Apr 2010, 10:41 am
cllwyrc's Avatar
Default cooling system ?
How do you properly bleed the cooling system on the pt cruisers? I don't think the repair shop is doing it the wright way.
Old 20 Apr 2010, 12:16 pm
Default Re: cooling system ?
Fill the system up to the top of the thermostat housing, close the radiator cap. Fill to the cool line of the overflow bottle. Run the engine till thermostat opens and CAREFULLY open the bleeder valve till no more air escapes. If there is air that comes out before the coolant starts to come out, Let the system cool down and add more coolant to take the place of the air that escaped. Might wnat to do that a couple times.
Old 21 Apr 2010, 12:23 pm
cllwyrc's Avatar
If this don't work what else can I do to get this car to run at normal temp & not keep trying to climb towards redline? Its had a new thermostat, a new temp sending unit, its had a radiator flush & the hoses are not colapsing. Can the radiator be bad or is there something more serious wrong?
Old 21 Apr 2010, 12:36 pm
Unhappy Re: cooling fan?
My daughter drives a 2007 PT... the temp gauge goes up when at idle, in traffic or at stop. The fan doesn't seem to go on, but when we jump it to check the speeds it goes on/works. There were times where disconnecting and reconnecting it seems to make it work for a day, but thats it. My husband did notice marks at the connection, as if it is shorting out. Can the connections be bad? Do I have to go out and get a new fan? I don't want to have to spend the money on a new fan if the problem isn't the fan....can someone help?
Old 21 Apr 2010, 04:07 pm
Angry Re: cooling system ?
I have the same problem..new thermostat, flushed system, new tubes...still have same problem. Overheats in traffic,stopligts,etc. So frustrating!
Old 21 Apr 2010, 07:57 pm
Dino's Avatar
Default Re: cooling fan?
It usually is the fan, sorry to say. Do a search for radiator fan and you will see it's usually the culprit.
Old 25 Apr 2010, 10:35 pm
cllwyrc's Avatar
I just had my radiator replaced and now I'm not getting a whole lot of heat threw the vents & when I turn on the defroster it will blow out warm then shortly after it blows cold, is my heater core clogged or what else could it be?
cooling fan no go on the low nealtotheking General PT Cruiser Discussions 10 03 Aug 2017 08:19 pm
over cooling christopher760407 Tech & Performance Forum 2 14 Mar 2010 09:55 pm
cooling off with snow careyk General PT Cruiser Discussions 1 25 Nov 2009 09:39 pm
A/C not cooling at all bigjoe1651 Tech & Performance Forum 5 10 Oct 2009 02:42 pm
Cooling Fan Mod AZ_IceMan Stage Turbo Kits 3 25 May 2005 04:07 am
