Belt change help - Not timing belt
Old 22 Apr 2010, 03:27 pm
Default Belt change help - Not timing belt
So I will be changing my accessory belts tomorrow and the large belt seems easy enough with the tensioner, but I dont see how to change the Alternator belt. I saw one post saying there is a 13mm bolt that you have to locate. Is that it? Does it work like the other belt with a tensioner or do you have to remove the alternator? Or maybe just take out two bolts?
Any help is appreciated. I can do a lot mechanically. I had the left wheel off and the splash guard off, just cant see any tensioner for the alternator.
Thanks Steve
2003 GT Auto w/ Air
Old 22 Apr 2010, 03:38 pm
Default Re: Belt change help - Not timing belt
No tensioner on the alternator drive belt. Loosen the alternator lower pivot bolt, loosen the lock nut (upper), loosen the adjustment screw (counterclockwise) until you can slip the belt off of the alternator pulley.
Old 23 Apr 2010, 11:23 am
Thanks Carl48
Just finished. I had to remove the bottom bolt all together to get enough slack on the Alternator belt to remove. Than that was the hardest part of the whole job, getting it back in. It took just over an hour total. Not too bad.
when to change Timing belt ? Ctown General PT Cruiser Discussions 13 18 Aug 2014 05:40 pm
Timing Belt Change Photos 68ranger390 Tech & Performance Forum 25 05 Jan 2011 12:11 am
Timing belt change turbomangt General Turbo Discussions 31 19 Jan 2009 04:48 pm
Timing Belt change calflan Tech & Performance Forum 1 23 Oct 2007 03:52 pm
After timing belt change no more Air Conditoning? Ctown General PT Cruiser Discussions 5 28 Mar 2006 01:24 am
